Old 05-17-2013, 07:22 AM   #1
talhahs
Drives: Toyota Yaris 2010 SD AT
A day out with mechanic went wrong- Right arm problem
Guys,, I purchased this used Yaris around 9 months back..I did the computer test and found the following issue which accoriding to mechanic at that time are tiny..
  • Right Arm
  • Right Scissors
  • Front shock absorbers
  • Engine Mount
Hence I decided to take it to mechanic this weekend, please note that I was not hearing any sound or experiencing any problem meanwhile. The mechanic changed Right Arm and engine mount...Front shock absorbers were fine according to him as there was no leakage.
Now the problem is , one of my front Tyre is more forward than the other. Please see below photos to understand. According to mechanic, the car must have had accident on its right. The denter was not able to fully recover the chassis and hence front right arm was forcefully pulled forward.. After installing the new arm, the problem became obvious.
My Qs:
- How critical is this problem?
talhahs is offline   Reply With Quote
Old 05-17-2013, 08:41 AM   #2
Amdkt7
Returning to Toyota
Drives: 2013 L 3dr MT
are the tires showing signs of un-even wear? This is not good, but maybe something you can live with. I'm sure it could be fixed, but might be not worth the expense, I don't know.
Amdkt7 is offline   Reply With Quote
Old 05-17-2013, 08:44 AM   #3
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
Pretty sure this will affect what is called "Caster angle" which can potentially make the car handle bad or be unpredictable since one side is dramatically different.
It will probably pull to one side or make it difficult to turn right (since it's on the right side.)
http://en.wikipedia.org/wiki/Caster_angle
Black_griffin6 is offline   Reply With Quote
Old 05-17-2013, 09:46 AM   #4
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
That's jacked up. Did the guy you bought it from tell you there was frame damage?
Old 05-17-2013, 10:04 AM   #5
toyotavios_11
Drives: Toyota Vios
u may need to replace the sub frame
toyotavios_11 is offline   Reply With Quote
Old 05-17-2013, 10:15 AM   #6
mr_miles
Drives: 2013 Yaris
maybe the subframe is just crooked? why not loosen the bolts down there and try to reset it?
Old 05-17-2013, 05:20 PM   #7
talhahs
@ Amdkt7 : It has been just a day, I couldn't figure out the uneven wear yet.
@47_MasoN_47 : Buying a used car from a USED CAR SHOWROOM with no guarantees and you expect them to tell u everything clean and straight :p
@toyotavios_11 and @mr_miles : I would discuss this sub-frame option with my mechanic, but I believe this must be expensive.
After city driving for few mins at speed approaching 60 km/hr, the car is posing not much problem yet but I have to drive really slow at speed-breakers as tyre touches the mud guard..
Arm rest problem!! Pattycake DIY / Maintenance / Service 9 08-13-2009 03:15 AM
Black Friday Bob_VT Off-topic / Other Cars / Everything else Discussions 70 11-29-2008 07:07 AM
The Official Having A Bad Day Thread. *MAD DOG* Off-topic / Other Cars / Everything else Discussions 7 11-15-2008 08:38 AM
