Old 05-09-2013, 10:36 AM   #1
Starrbri
Drives: 2007 yaris sedan standard
Oil Check Question
I am parked in my work garage (on an incline). I walked out to my car and noticed some oil on the ground underneath the car. It does not appear to be from my car, but it is near the drain plug. I think it is just a coincidence. But the auto hypochondriac in me wants to just confirm.
Question, is there a way to check the oil while the car is parked on an incline? The front of the car is higher than the rear. Will this give me a lower or higher reading? The car has been parked for 3 hours. How does checking a cold engine compare with warm?
Thanks!
Starrbri is offline   Reply With Quote
Old 05-09-2013, 11:30 AM   #2
DMZ
DMZ's Avatar
Drives: 2007 Yaris LB
The reading will be high (front end low) or low (front end high), if the car is on an incline. Pull the car onto a level surface and check it hot. It should give you a good read on where the level is at.
If you think there is a seep at the plug. Wipe it off good and look at it an hour later. It should still be dry and oil free. If not, replace the crush washer.
2007 LB W/Cold Wx Package
DMZ is offline   Reply With Quote
Old 05-09-2013, 05:21 PM   #3
jcboy
Drives: Sedan 07
do a reading on an incline and it will be inaccurate, same with a warm engine.
all readings should be on a level surface and at least 3 hours parked (overnight = better) to make sure all the oil has settled on the pan. otherwise, if you do it hot you might overfill the engine since the reading will be less (since some of the oils are in circulation inside the engine) and the tendency is to fill it up with more oil.
Old 05-09-2013, 11:06 PM   #4
Hershey
Check it in the morning or sometime the following day .
Old 05-10-2013, 06:03 AM   #5
Lippitt
Drives: honda accord
I wouldn't even bother trying on an incline, you won't benefit from it, just wait till you get it on a flat then try as said above.
Lippitt is offline   Reply With Quote
Old 05-10-2013, 06:21 AM   #6
bronsin
bronsin's Avatar
1) Park your car on a level surface for at least five minutes after shutting off the engine.
2) Check the oil level and if not full, add oil to make it full.
3) Park in your spot on the incline and check the oil. Where ever the oil level is make a mark on the dipstick in the metal of it some how. Not with a pencil youll have to score the metal.
Thats your new full mark!
OR:
Check your oil at work or after grocery shopping in a level site.
Old 05-10-2013, 08:09 AM   #7
Starrbri
Thanks guys. It turns out that pool of oil didn't belong to me. I pulled out of the garage and parked on a flat surface, oil full. Also I didn't see any oil underneath the car this morning. Some poor sap is driving around with a large oil leak... Or was
Old 05-10-2013, 11:37 PM   #8
Starrbri
I may have spoke too soon. I just changed my oil and discovered no crush gasket... I searched everywhere. Pan, ground, pan, sifted through the oil. Nothing. Unfortunately I did not have a spare gasket. Off to the auto parts store in the morning
Old 05-11-2013, 09:14 AM   #9
bronsin
bronsin's Avatar
Hmm not many people here would admit that. I once was on the turnpike and noticed a shower of sparks coming from underneath a truck that was passing me. I thought "Look at that idiot. He doesnt even know sparks are coming out of his truck!"
He passed me and the sparks were still there.
They were from MY car.
Old 05-11-2013, 07:14 PM   #10
nookandcrannycar
Years ago I was driving from Squaw Valley, CA to Carnelian Bay, CA with some friends after a day of skiing. We had almost reached Carnelian Bay when I realized that I had left my Day Planner (with my DL, bankcard, money, etc. in it) on top of the car. I pulled over at the next safe point and the ski rack had kept the Day Planner on top of the car (!) during the somewhat twisty journey.
Old 05-11-2013, 07:22 PM   #11
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
My friends and I were driving once, sand same thing except we left a wallet ON THE BACK BUMPER of the car. We found it at the destination when we go out, and it was by accident we saw it there too.
Old 05-11-2013, 07:32 PM   #12
nookandcrannycar
Wow, that is more amazing than what happened in my situation....nothing to help hold it in place.
Old 05-16-2013, 05:25 PM   #13
Amdkt7
Returning to Toyota
Drives: 2013 L 3dr MT
I Never put things on top of the car! I always forget! That being said, I put my hiking GPS on top of the car recently while I was getting ready to go hiking. Discovered the GPS was missing, and was not where I swore it was in the car that morning. Hunted for five minutes, finally gave up, then I spotted it, on top of the car...
As far as your oil plug washer, I am confused. You were full of oil, yet missing the washer? I'm guessing that you discovered that you forgot the washer, but that it was not actually leaking.
Amdkt7 is offline   Reply With Quote
Old 05-16-2013, 06:49 PM   #14
nookandcrannycar
In 2010 I saw a movie in Austin and was going to drive back to Montgomery County afterwards. After the movie I realized It was a relative's birthday and that I needed to send an e-card before her birthday ended in California (which would happen before being able to get back to Montgomery County). I searched around for and found a Starbucks. It was closed, but I tried to connect to their Wi-Fi signal from my car (usually not a problem), but to no avail. I decided to look for another signal, but then couldn't find my car key. I turned my car upside down and finally found the key in the chest pocket of the shirt I had on (). I found a McDonalds and sent an e-card from my car. I found my way back to I-35 and after about 7 miles or so I reached for my phone. No luck. I realized I left it on top of my car when I was turning my car 'upside down'. I drove back to the Starbucks and searched the parking lot with a fine toothed comb. Didn't find it. I lost all the information that was in the phone (it wasn't a smart phone).
Old 05-16-2013, 06:56 PM   #15
Amdkt7
Returning to Toyota
My worst experience looking for a lost object was when I was working on a car late at night. I could not find the wrench that I had just used. I walked around with a flashlight for 15 minutes getting madder and madder. Finally I gave up for the night, and began putting everything down that I was holding.... I was holding the damn wrench the whole time! I was in my twenties then.
I have learned also to never put my keys down inside the car. Never. Put them in my pocket so they leave the car with me! I have set them down inside the trunk and promptly locked it.
Old 05-16-2013, 09:27 PM   #16
nookandcrannycar
LOL. I've done that a couple of times -- start to look for something and then realize I'm holding it in my hand.
I have gotten much better re this .
Old 05-16-2013, 11:00 PM   #17
Hershey
Good thing for some that the TOOL isn't detachable . Would hurt like to slam the hood down it after checking the oil level . Can thank Sam Kinison for that funny memory .
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Did I overfill my oil? zkay DIY / Maintenance / Service 10 06-20-2012 10:59 AM
When should I start using synthetic oil?? trwxxa DIY / Maintenance / Service 68 06-29-2009 06:16 PM
Noob engine oil question. Do I HAVE to use 5w-20? (closed) yarisugi DIY / Maintenance / Service 5 11-09-2008 05:34 AM
Oil change question: asa805 DIY / Maintenance / Service 5 11-29-2006 09:54 PM
