Old 07-18-2012, 10:13 AM   #1
Jerkratt
Jerkratt's Avatar
Turbotrix working on ECU Flash
Turbotrix a tuning shop by me is in the process of getting an ECU flash for our stock ECU's. if anybody is interested i suggest you bookmark this thread. they are very well known around here. i have been speaking with a guy named Eric
"It hurts more when its wet"
Jerkratt is offline
Old 07-18-2012, 12:27 PM   #2
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
would this be for an N/A setup or forced induction setup? interesting and interested.
how much are they talking price wise?
BEEF is offline
Old 07-18-2012, 01:32 PM   #3
That's awesome. [subscribed]
cali yaris is offline
Old 07-18-2012, 04:06 PM   #4
Jerkratt
Jerkratt's Avatar
Don't have much info atm all I know is the ECU is already being looked at. I'll have more info soon
Jerkratt is offline
Old 07-18-2012, 05:38 PM   #5
XFACOR
Drives: 1nz-fe
Will be interesting to see what they do. The only place I'm aware of that even fools around with Toyota ECU's is TOM's in JAPAN.
Which is who I'm using to dvelop some new stuff. The Toyota ECU is a tough nut to crack.
XFACOR is offline
Old 07-18-2012, 07:40 PM   #6
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I have personally known a couple guys that are pretty sharp like CTScott and they fried close to a dozen Toyota ECUs between them. Interesting to know someone is giving it another whirl and best of luck to them. I would think that the most useful adjustment would be to fool the ECU/ECM about the voltage on the stock front O2 sensor to prevent it from causing issues with Piggybacks and LTFTs.
fnkngrv is offline
Old 07-18-2012, 09:57 PM   #7
Radou
Radou's Avatar
Drives: yaris 09 ncp91
i follow this !!!
Radou is offline
Old 07-18-2012, 10:44 PM   #8
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
These guys do ecu tunes for the Yaris.
http://www.dynotronicstuning.com/
No affiliation just letting you know.
xnamerxx is offline
Old 07-19-2012, 04:21 PM   #9
Jason@SportsCar
Wow, did not know they had cracked it. Joe (aka McTexas) does great work, if anyone can get the Yaris ECU to make power it will be him.
Jason@SportsCar is offline
Old 07-19-2012, 04:14 PM   #10
thefalls
Drives: Axio GT
This is going to be interesting....As said earlier,toyota ecus are quite tough to crack.
thefalls is offline
Old 07-19-2012, 05:45 PM   #11
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
cracking the ecu is one thing, interpretation into understandable values and software to change those values... is another.
Ptuning.com
Blown_xa is offline
Old 07-19-2012, 06:05 PM   #12
Jerkratt
Jerkratt's Avatar
All I know atm is its sent out any further news will be posted as I find out
Jerkratt is offline
Old 09-03-2012, 10:01 PM   #13
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
any update?
Bluevitz-rs is offline
Old 09-03-2012, 10:27 PM   #14
vten
subscribed ....
vten is offline
Old 09-15-2012, 03:17 PM   #15
Jerkratt
Jerkratt's Avatar
Called the other day. I they said to call back Monday so he can call his flasher and find out status
Jerkratt is offline
Old 10-03-2012, 11:10 AM   #16
Jerkratt
Jerkratt's Avatar
So still have not heard anything back from them.. So mean while found a tuner for the FiC. Now I have all my problems solved and if anyone lives in the tri state area he's in Yonkers.. IF/WHEN I get more info from turbo trix regarding the flash I will post updates. Mean while if anyone needs tuning/dyno let me know
Jerkratt is offline
Old 05-06-2013, 05:09 PM   #17
Jerkratt
Jerkratt's Avatar
mods please close this thread as the person iw as dealing with does not work there anymore
Jerkratt is offline
Old 05-06-2013, 10:22 PM   #18
Keep it open, and let's discuss this instead.
Yaris ECU broken??!!!!!! phb10186 General Yaris / Vitz Discussion 30 05-26-2010 09:56 AM
Parking Light Flash Output vs Hazard Light Output sex DIY / Maintenance / Service 2 11-03-2009 08:47 PM
wanted a 08 yaris lb automatic trans working ecu unit pennyracer Willing to Buy by private party 0 08-27-2009 11:26 PM
Tricking the ECU to Relearn AF map gwasabi Performance Modifications 126 05-16-2009 06:15 PM
