Old 08-12-2013, 12:16 PM   #1
Mittelklasse
Problem, officer?
Mittelklasse's Avatar
Drives: '06 Yaris 5DLB 1.5
Big 3 upgrade: grounding ALT directly to BATT?
Hi, I am planning to do the Big 3 upgrade, and here is my question:
Would it be better to connect a ground strap from the alternator body to the battery negative, rather than to the chassis?
I will be using 25 sq.mm. cable which is equivalent to 4 AWG.
My rationale is that in the stock setup, the alt was grounded to the batt via the engine ground strap.
By connecting directly from the alt to the batt negative, the reduction of resistance could be realized as there will be less connectors in the path.
(Therefore, lower voltage drop)
My car has stock audio system. I plan to do this upgrade mainly for engine efficiency and fuel economy.
Mittelklasse is offline   Reply With Quote
Big 3 Upgrade in '09 Sedan! (w/pics) typicaljawaiian808 In Car Entertainment + Electronics (audio / video / alarm) 20 08-17-2017 01:05 PM
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
Big 3 Upgrade: Planning Stage (Input Encouraged) The Architect In Car Entertainment + Electronics (audio / video / alarm) 144 02-01-2012 07:58 PM
Basic Big Three Upgrade done on our Engine VIDEO: Scion XB Gen. 1 The Architect In Car Entertainment + Electronics (audio / video / alarm) 2 09-02-2009 06:18 AM
The Big One upgrade fuji DIY / Maintenance / Service 2 02-15-2009 02:37 AM
