Old 07-24-2013, 01:29 PM   #1
vaironl
vaironl's Avatar
Drives: 2010 Yaris 3 door, manual tran
2010 coupe Yaris power outlet not working
Hello everyone,
A couple of days ago I found out the power outlet does not work in my Yaris. It seems to have build some sort of rust. Does anyone have any idea of what I could had happened to it? I did get it from a dealer less than a month ago so I think I can call them.
vaironl is offline   Reply With Quote
Old 07-24-2013, 03:12 PM   #2
It is not uncommon for the inside of the outlet to rust. Check the 15A CIG fuse in the fuse panel that is under the bottom of the dash to see if it is popped.
Old 07-24-2013, 03:40 PM   #3
vaironl
vaironl's Avatar
So all i have to check is if the fuse wires are broken (not touching), correct?
Old 07-24-2013, 04:09 PM   #4
Correct - The metal piece inside of the plastic should be complete.
Old 07-24-2013, 04:30 PM   #5
vaironl
vaironl's Avatar
It doesn't seem broken but it looks like if its burned, literary like if someone held the metal parts over fire.
Old 07-24-2013, 04:33 PM   #6
vaironl
vaironl's Avatar
I'll replace it by the spare 15 on the front.
Old 08-04-2013, 09:12 PM   #7
vaironl
vaironl's Avatar
Hey Scott, I'm sorry to revive this thread now. I don't know why I didn't posted my problem, but after placing the new fuse the power outlet still didn't work. I'm guessing I will have to remove the panels and do some work. Do you think I can follow this DIY: http://www.yarisworld.com/forums/showthread.php?t=9431 ?
Might I need additional tools?
My car has the same panel and the outlet is in the same spot. I will replace the outlet itself because it looks like this
Old 08-04-2013, 09:24 PM   #8
That DIY would be fine for getting at it to replace it.
Old 08-14-2013, 09:59 AM   #9
vaironl
vaironl's Avatar
Fixed!
I don't know if it was necessary, but I disconnected the battery anyways. Then opened the front panel and thought I was going to have to replace the power outlet, little did I know the cable supplying power was disconnected .
Previous owner probably messed with something in there.
Thanks for the help!!!
2007 yaris sedon power outlet problem 23carlie23 DIY / Maintenance / Service 2 03-21-2010 10:36 AM
