Old 09-23-2013, 01:30 PM   #1
bairjo
Mass air flow sensor cleanin question
So I was at Orielys today to get some mass air flow sensor spray cleaner to do a pm cleaning. The clerk sugessted i put some bulb grease in the electrical plug when i put it back together. So i thought..okay, he must know what he talking about. However, when i pulled the thing apart there was no grease in the plug with multiple wires going to it. I opted not to put the bulb grease in the connection. My question is..was he correct? Is it a good idea to dab some bulb grease in this connecton?
Old 09-23-2013, 01:52 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
There is a gasket around the connector to prevent water penetration. Rubber/Silicone will eventually dry out and let water in. It is a matter of time, so yeah.. i would definitely put some non-conductive grease in there. But you really don't have to...
Old 09-23-2013, 01:52 PM   #3
Connectors with rubber seals, like the MAF connector really do not need dielectric grease.
Old 09-23-2013, 07:23 PM   #4
bairjo
Thank you.
WTS Jet Power Flow MAF Sensor yangjiesheng Items for Sale by private party 2 06-13-2013 02:29 PM
HKS Super Power Flow Reloaded Open Pod Air Filter yuxian Performance Modifications 4 04-05-2013 12:05 AM
Air Flow switch problem aucorium DIY / Maintenance / Service 5 01-15-2007 04:54 PM
