Old 09-24-2013, 07:44 PM   #1
oliveskate
Drives: Toyota Yaris
Installing MI Crank Pulley?
Well I'm going to install my MI Crank pulley again.
Last time I had a glazed belt and that just caused issues so i removed it and re-installed the factory one because I thought it was the pulley it self. But I'm thinking I had the belt too loose/or too tight.
Just have some questions.
I got a fairly new serpentine belt (oem with around 5000kms on it)
so that should be good with the pulley im guessing?
Also when I have the new pulley installed, I should probably be able to only twist the belt 90 degrees? Or is their another way I can tell the proper tension on it?
Also after I have the car idling for 10 minutes or so with the new pulley on, should I re-adjust the belt?
Thanks you.
oliveskate is offline   Reply With Quote
Old 09-24-2013, 09:08 PM   #2
The belt shouldn't deflect more than 1/2" when you press on a long section of it
Old 09-24-2013, 09:40 PM   #3
Twisting isn't a good measure. Deflection (how far you can press against the belt is the proper measure). I don't remember the exact deflection measurement off the top of my head, but I posted it in a couple of the other belt threads.
There is a real tool for measuring deflection, but I prefer to use my finger tip. Pressing on the middle of the long stretch of the belt with your finger tip the belt should only deflect the amount of the rated deflection.
Old 09-24-2013, 10:21 PM   #4
CharlieBravo
CharlieBravo's Avatar
Drives: 2007 Yaris HB
Please post pics of the install! I may be getting one soon!
CharlieBravo is offline   Reply With Quote
Old 09-25-2013, 12:19 PM   #5
I believe that because the belt already has 5000 kn, no readjustment would be necessary.
You have to re-adjust it, because you have to loosen the alternator to swap the pulleys.
Micro Image crank pulley - prototype complete! cali yaris Micro Image 111 11-10-2014 10:24 AM
NST OEM Lite Crank Pulley or NST 10% Underdrive Crank Pulley 1.5L Tylermayer Performance Modifications 2 06-02-2011 08:03 PM
NST Lite Crank Pulley camelll Items for Sale by private party 5 03-15-2011 08:57 AM
NST Crank Pulley Swap/Trade The Architect Items for Sale by private party 2 11-16-2010 01:11 PM
NEW GROUP BUY: NST WP-Lite & ALT-Lite Pulley Kit (NonStopTuning) NonStopTuning NonStopTuning 266 09-29-2007 02:51 AM
