Old 08-11-2011, 11:34 PM   #1
halifaxyaris
Drives: 2007 yaris
Lower control arm bolt snapped .. while the car was parked
While stopped for gas in Maine this week (on vacation), I heard a pop/snap. Looked under the car I noticed a bolt head snapped off. I didn't immediately spot the problem until I went over a bump and braked. I looked under the car while the front weeks were turned and noticed the lower control arm, separated from the frame. 7.5 hours of labor, and $10.50 in parts, I'm back on my way. Thanks to Oregans Halifax, and Breton Toyota Sydney, for not looking out for me. This could have been clearly avoided if the service people were a little pro active, and simply replaced the two bolts before they snapped off. The car has 97,000 km and has always been dealer serviced ( including a recent MVI ) Shame on Toyota for using sub standard parts. Clearly a recall should be in the works.
halifaxyaris is offline   Reply With Quote
Old 08-12-2011, 01:36 AM   #2
Viperoni
Drives: 2005 Toyota Echo
Pro active on replacing bolts that are not wear items in any sense and should have never failed like this to begin with?
I do agree with weak bolts though, there's a couple engine bay bolts that I've loosened that snapped which should not have under the pressure that they did. A suspension bolt should be at least a Grade 8 bolt and normally doesnt' break unless other conditions are present (like it's loose for some reason).
2006 Saturn Ion Redline
Old 08-12-2011, 06:11 AM   #3
There is a TSB for those bolts corroding and snapping.
Old 08-12-2011, 01:04 PM   #4
yaris2010RS
yaris2010RS's Avatar
i thought the issue was only on the early 2007's
Old 08-12-2011, 02:14 PM   #5
2007 - 2011
T-SB-0055-11 Clunk Noise from Front Suspension.pdf
Old 08-12-2011, 10:03 PM   #6
CB900F2
Drives: 08 Sedan
Scott.. Where did you find the TSB??
Thanks Scott
2007 - 2011
Attachment 43341
CB900F2 is offline   Reply With Quote
Old 08-12-2011, 10:30 PM   #7
Thanks Scott
TIS
Old 09-10-2011, 07:59 PM   #8
yaris2010RS
2007 - 2011
Attachment 43341
also from looking at this TSB it says we need more then just the bolt? is this correct? im afraid to have toyota do the job under warranty as my car is lowered and is quite other wise moddified
Old 09-11-2011, 04:53 PM   #9
MUSKOKA800
MUSKOKA800's Avatar
The Toyota Canada TSB showed only bolt replacement for my '08 sedan. No mention of control arm or cross-member replacement and about 3 hours instead of the 5.5 hours stated in the US TSB. Other production years or models could differ of course.
The bolts are supposed to be an updated part. Hopefully that means better.
Old 08-12-2011, 02:24 PM   #10
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i was at toyota a month ago for my water pump howcome they didnt tell me about this..??
Old 08-12-2011, 02:27 PM   #11
Because a TSB is not a recall. It is an informational document that saves technicians troubleshooting time on known issues.
Old 08-12-2011, 04:21 PM   #12
MUSKOKA800
MUSKOKA800's Avatar
So it's a lot more than a bad bolt if a whole component need be replaced.
OR that bolt was under-torqued and the resultant free-play would damage the other pricey part.
Thankfully my out of warranty 2008 sedan has exibited no such pricey clunk.
Old 08-13-2011, 09:09 AM   #13
Viperoni
WOW they recommend a new cross member along with new CA's and a particular bolt. Damm.
Sounds like the bad bolts wear a hole into the CM as they break or something along those lines. Interesting.
At this rate you guys might as well get those bolts swapped out before they break so you don't have to go through the extra expense, shouldn't take more than 20 minutes on a hoist.
Old 08-12-2011, 07:32 PM   #14
yaris2010RS
ooo im gonna go to toyota and say my car is clunking
Old 08-19-2011, 04:56 PM   #15
MUSKOKA800
MUSKOKA800's Avatar
Perhaps I spoke too soon!
Clunking started Wed. afternoon. I'll run it up the ramps tomorrow and investigate. Sounds like the symptoms in the TSB. Clunk when braking, then clunk with re-accellerating and clunk over bumps.
Of course my warranty is done and it doesn't look like a driveway job.
Cha-ching!!! This may be our first trip to the service department. :(
Update: Sure enough, the head of the drivers side control arm rear bolt is gone. It broke off at the head so the stud is still intact so the arm cannot become dislodged.
I'll investigate other more reasonable solutions on Monday as the TSB is a very pricey process.
Old 08-22-2011, 04:27 PM   #16
MUSKOKA800
MUSKOKA800's Avatar
Update:
Visited Burlington Toyota/Scion this afternoon.
In Canada the TSB includes only the new, improved bolts. No new cross-member or control arms are specified. Approx. 3.5 hours (at $98.00 per hour) labour plus an alignment at ~$99.00. The bolts are ~$8.50 each.
Tomorrow an independant shop will investigate whether they can remove the broken bolt without dis-assembling the front end. Welding a large nut to the bolt shaft may be an option. A much cheaper one.
Old 08-22-2011, 06:35 PM   #17
Viperoni
Update:
I was gonna say that welding another nut/etc onto the existing piece should do the trick if there's enough material protruding past the subframe.
Keep my fingers cross for ya!
Old 08-23-2011, 01:42 AM   #18
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
sounds like a crappy TSB for sure!
What Car Mechanics Don't Want You to Know!! daddz07 DIY / Maintenance / Service 16 04-17-2011 10:10 PM
Control Arm Broke last night Yaris PAVEL94 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 04-02-2011 07:39 PM
DIY Ultra racing lower arm brace seechoong DIY / Maintenance / Service 3 10-07-2010 11:42 AM
Photo Scavenger Hunt Ideas Thread Black Yaris Photo-Video-Media Gallery 41 02-28-2009 08:54 PM
