Old 12-10-2013, 09:26 AM   #1
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
16" x 7 inch offset 35, ok??
Hi all,
Currently I am considering to upgrade my 15inch to 16inch Enkei RPF1 7 inch wide offset @ 35mm.
My ride is is using Tanabe NF210 spring. I intend to use 205/45/16. Will I have rubbing issue with the above set up?
I am using 15 x 6.5inch with 1.5degree of camber now... The front wheel kind of too in inside the fender. The main reason i want to up-size is for the width of the rims 7inch and wider 205 tires and more flash look without rubbing issue.
Any advices?
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
evo165 is offline   Reply With Quote
NJ CL find: Authentic TRD Model T3 16" Wheels (4x100) +42 offset with tires - $400 sex NY / NJ/ CT / PA 3 04-02-2012 10:06 AM
PLEASE HELP! 15x8 wheels contraband831 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 76 06-30-2007 10:34 AM
need 17inch rim guidence chino_potato Wheels, Tires and Suspension Forum sponsored by The Tire Rack 46 04-09-2007 12:09 PM
