Old 04-23-2014, 01:08 PM   #1
I want my mpg back...
...and now hopefully I'll get it.
After years of forcing the car to push around +sized wheels, I'd decided to return to OE sizing this year and see what happens. Struck a deal with Exiwolfman a while back and picked up these tiny suckers yesterday.
Bronze painted OE Prius wheels (don't know what vintage). 14X5.5 clad in 175/65/14 Hero rubber (don't know what those are but they sure run quiet).
Setup is 25lbs per corner. 8lbs lighter than my prior 17x7 Enkei PF01s wrapped in Kumho 215/40/17. Should also mention that these are 1.5lbs lighter than the 175/65/14 Goodyear Nordics on OE steelies that just came off for the summer.
Now to get my Meagan springs back on to get her squatting some. Crazy rear wheel tuck that I can't do much about. What you see is with 10mm spacers mounted. Eliminating my camber could help a bit I guess.
Old 04-23-2014, 01:15 PM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
They look good. Pretty sure they'll look even better once you lower it a tad more. You should also probably feel the car to be much peppier now. Well done!
Old 04-23-2014, 01:27 PM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
yup..wheels and tires can make a huge difference that is for sure. When I moved back to 15" a couple years ago it was a drastic "upgrade" compared to being on the 18" I had been. Went from 52lbs per corner to near where you are. Will be interesting to see if your mpg does improve. I have made too many performance mods in between to tell in my case.
Old 04-23-2014, 01:53 PM   #4
Doing a little research on Hero tires
Brief History
Hero Tires began as Nanchang Rubber Plant in 1956 producing galoshes and rubber shoes. A year later, it merged with Nanchang City Car Repair Plant and Third Rubber Plant and in 1960, began production of bias PCR tires. Production of agricultural tires soon followed and in 1977, Nanchang Rubber Plant was declared as one of the top 16 major tire manufacturers in China . Motorcycle tire production began in 1980 and in 1984; the company was renamed as JiangXi Rubber Plant.
In 1997, Federal Corporation acquired 100% ownership of JiangXi Rubber Plant and changed its name to JiangXi Federal Tire (JFT). Under Federal's leadership and management, JFT entered into commercial tire production. Beginning in 1999, it began mass production of Hero brand tires, launched 60 to 80 series radials, followed by 50/55 series and 40/45 series and also began mass production of Federal brand tires. Today, Hero has consolidated its tires into 5 major families to fully serve our customers worldwide.
Old 04-23-2014, 02:09 PM   #5
IllusionX
Drives: 07 Yaris Sedan Aero
You should go with 175/65R15 with a set of ultra light weight 15" rims for better mileage.
Old 04-23-2014, 02:15 PM   #6
^ what's the point of that!
I've already done what I've done. Not going to turn around and do something different just yet.
Old 04-23-2014, 03:59 PM   #7
IllusionX
well, if that works for you! :)
keep us posted. You are doing 4% more mileage with these tires than with OEM 185/60R15, so you have to take this into consideration.
Old 06-27-2014, 07:29 AM   #8
Happy Stats
Originally Posted by IllusionX View Post
keep us posted.
Two months running this setup and on average, slightly better f/e than I did with the 14" OE Bridgstone/Steelie combo.
...and yesterday, recorded my best ever of 5.06 l/100km (46.51 mpg) My prior best had been 6.11 l/100km
Old 04-23-2014, 02:38 PM   #9
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Looking good ...think they look better on white then silver ...enjoy :)
Sent from my XT1032 using Tapatalk
Old 04-23-2014, 03:00 PM   #10
fnkngrv
fnkngrv's Avatar
yeah...I agree that they look nice with the white body.
Old 04-23-2014, 04:33 PM   #11
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
OEM is 175 65 14 they change size on 08 up to 185 60 15 ...its .5 deference in diameter
Old 04-23-2014, 05:26 PM   #12
Exactly. The 2006 OE 175/65/14 Bridgestone Potenza mounted on steelies set the benchmark for me. MPG for every set of wheels I've had since are compared to the OE numbers, factoring in slight sizing discrepancies between setups.
Old 06-28-2014, 02:18 PM   #13
nookandcrannycar
07s (at least 3-door USDM models...mine included) with the optional convenience package also = stock 185/60-15 size tires.
Old 04-23-2014, 05:57 PM   #14
IllusionX
I always forget that LE comes in 14 back then.
Old 04-23-2014, 06:56 PM   #15
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
When i used the 14 that Weeyari got from me my best tank full to empty was just under 800 km with one bar left ...that was mainly on country roads in my area and going to school part time in Toronto...average speed around 100 . I drive a 5 speed CE two door base , light and simple .
Old 04-24-2014, 08:12 AM   #16
IllusionX
My best was 6L/100km, on 195/55R15 yokohama S.Drive @ 33PSI on my way to tdot. 120kmh with AC on.
Now that i do mostly urban driving with lots of stop and go, i avg 7L/100km in the summer.
Old 04-24-2014, 08:37 AM   #17
What goes around, comes around...
March 2009; Tenzo Racing DC-6 v1 16s
Old 04-24-2014, 09:23 AM   #18
IllusionX
huh.. looks the same as now LOL
prius wheels
MI SSK In-Cabin DIY (Golddeenoh) BEEF DIY / Maintenance / Service 5 03-26-2013 01:19 PM
Better MPG in the City vs. Hwy Loren Fuel Economy Forum 21 01-29-2010 11:49 AM
Why is my new 09 Yaris MPG is so low soup1207 Fuel Economy Forum 34 06-12-2009 03:45 PM
Anyone from Missouri? MPG problems inside 4MPG Fuel Economy Forum 31 12-17-2008 05:48 PM
Toyota Yaris MPG Review at www.mpgomatic.com aca72 Fuel Economy Forum 23 10-31-2008 03:59 PM
