![]() ![]() Drives: Yaris 2008 HB 1.5 Join Date: Nov 2009
Car battery 12V 75AH
Hello, I've been using a 12 V 75 AH batt (first and second)
Now I'm replacing the second battery, the new (third) is 12V 55 AH (there is no 75 AH actually in store) At the fisrt milles the car looks like loosing power (by aceleration keeps power on). Now after running 15 milles the car works fine. Is enought the 12V 55AH or should replace for 75AH? This is a Yaris HB 2008 1.5 |
The original Toyota battery is only a 45 Ah battery, so the 55 Ah is sufficient. The question is why are you going through batteries so quickly?
The constant heat in central america sure is a killer to car batteries.
Embracing Curves
Drives: '14 Prius Executive Join Date: Aug 2013
In this country the batts life average is 2 years (some months more). I was using 75 ah because the car comes with 75 ah, but now I have been using the 55 ah for 4 days and works fine. Thanks for the replies.
![]() ![]() ![]() Drives: 2008 Sedan A/T Silver Join Date: Nov 2008
The same thing happened to me. After 5 and 1/2 years, I replaced my car battery with a new one. The first few miles, my engine was idling so close to 500 that I thought it was going to stall. As I was driving, the RPM would drop really low as soon as I came to a stop. After 15 minutes, it returned to normal. I was almost going to return the new battery.
#7 | |
![]() ![]() ![]() Drives: 08Yaris2D, 88LandCruiser. Join Date: Jan 2013
I think the key is an AGM type battery.
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
![]() Drives: yaris verso 2001 Join Date: Jan 2014
afternoon all
battery incorrectly installed thus issues with fuses short: Took a plane trip, battery down on return charged battery put in backwards - and + (yes i know) was that kind of a day saw sparks so stopped and found no response from victim (car) researched here and elsewhere ![]() found a 'fusible link' wire at a wreckers which he gave me nice guy replaced it and the 15 A "dome" fuse car works great only radio, light and clock are off any suggestions? many thanks for the help will review all the other fuses as well first while waiting happy new year 2013 all Boyd |
15 Amp fuse 'blew' 2 more times
The Yaris does not have any significant reverse voltage protection, so you can do some serious damage connecting a battery backwards.
To start with, disconnect the two ECM (engine computer) connectors and see if DOME fuse still blows. If it does not, then you may have damaged the ECM (which is the most sensitive device to reverse voltage).
oh and there are reverse polarity batteries out there... just beware when you buy it.
| Tags |
| battery |
| Battery keeps going dead | Outdoorsman | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 09-09-2013 05:43 PM |
| My car doesn't start | yaristhebest | General Yaris / Vitz Discussion | 11 | 01-10-2013 11:02 PM |
| Jerkratt - Photo Scavenger Hunt | Jerkratt | Photo-Video-Media Gallery | 3 | 03-04-2009 10:03 AM |
| thewifesyaris - photo scavenger hunt | thewifesyaris | Photo-Video-Media Gallery | 0 | 03-01-2009 07:02 PM |
