Old 01-22-2014, 09:08 PM   #1
mEKamonkey
mEKamonkey's Avatar
Drives: 2009 hatch
Low idle under load
Hello all,
Question my 2009's idle bogs to the point of almost stalling while the lights are on and the heater is running should I just set the idle screw in the throttle body a bit or unplug the battery to reset the ECU, or something else? Thanks!
mEKamonkey is offline   Reply With Quote
Old 01-22-2014, 09:15 PM   #2
Did you by any chance disconnect or run the battery down recently? If so, then you it is likely due to the throttle position zero being off because of carbon deposits. If that is the case, cleaning the throttle body and then resetting the ECM will improve it.
Old 01-22-2014, 09:17 PM   #3
mEKamonkey
mEKamonkey's Avatar
Drives: 2009 hatch
Just got the car used actually so I'm not sure, I'll give those a shot though thanks!
Old 01-22-2014, 09:22 PM   #4
mEKamonkey
mEKamonkey's Avatar
Drives: 2009 hatch
Just a quick note resetting the ECM is done by DCin the battery for a few right?
Old 01-22-2014, 09:40 PM   #5
Correct
Old 01-22-2014, 09:47 PM   #6
mEKamonkey
mEKamonkey's Avatar
Drives: 2009 hatch
Thanks again! man I love these forums..installed a tac, painted my badges and found people doing a group drive in my soon to be state..
Old 01-23-2014, 01:10 PM   #7
mEKamonkey
mEKamonkey's Avatar
Drives: 2009 hatch
ECM reset and a little nudge on the idle screw and all is well thanks again CT!
Yaris Japan's "Mini"..
Old 01-23-2014, 01:21 PM   #8
Excellent! And, by the way, welcome to the forum.
Low RPM when Idle Betrivent DIY / Maintenance / Service 12 03-03-2013 06:55 PM
Idle low yariseggvvti DIY / Maintenance / Service 14 12-17-2012 12:04 PM
Help with low idle from Venezuela Yarisvene DIY / Maintenance / Service 5 06-23-2007 08:23 AM
Low idle speed gonzo452001 DIY / Maintenance / Service 9 02-21-2007 08:41 PM
