![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
Exhaust sound "scientific" testing
For fun, I did a little exhaust note test @ Idle and 3100RPM. Hope this will help people find exhaust they want.
Car Specs: No Boost AFE Intake 50400miles on the ODO OEM everything else engine/exhaust related besides the tested items Setup: Engine warmed up to normal operating temperatures ~175F from my reading 3 feet distance from bumper inline with the exhaust 48khz 16bit. Manual mic level. Only after the fact did I realize, i had both a compressor AND high pass filter on at 237Hz on all of them, so not sure how that may affect the bass of each exhaust, massive Fail on my part. *I do not have a stock exhaust to test to set a baseline. Tested: Muffler Delete (No pipe): https://www.dropbox.com/s/8c16khmt24...0No%20Pipe.wav DC Sport Axleback: https://www.dropbox.com/s/h8l28gm71l...DC%20Sport.wav Resonator Back (straight pipe): https://www.dropbox.com/s/iesbvnv8xs...Res%20Back.wav
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 Last edited by ezhacker1; 02-10-2014 at 11:43 PM. |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
3 is definitely no pipe
2 is the Megan 1 is the straight pipe... I like that one. How did I do? ![]() Here's my through the bumper exhaust... http://www.youtube.com/watch?v=e2X9wPQE2Zw Greg |
So very close just switched 2 around, and I know you meant DC sport not megan.
It's interesting you liked number one. *Looks like no one wants to play. The original post to reflect answers. It is interesting to note that the sound of the muffler delete sounds actually good, only cuz the recorder wasnt put up next to the pipe opening. The sound bouncing around the house garage also makes it sound nice, verse the other two the exhaust vented straight out the garage door.
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 Last edited by ezhacker1; 01-27-2014 at 02:38 AM. |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| Micro Image center exhaust... | tooter | Performance Modifications | 64 | 10-14-2012 11:07 PM |
| Bad exhaust sound but no bad exhaust! | xexman44 | DIY / Maintenance / Service | 6 | 09-17-2012 09:35 PM |
| TRD exhaust sound clip VID | auxmike | Performance Modifications | 3 | 07-12-2009 11:24 PM |
