Old 05-02-2014, 10:32 AM   #1
Swing
Drives: Yaris P1, MR2 mk1, 4x4 Hiace
Pulleys interchangeable?
Are crankshaft pulley's interchangeable between all Yaris engines? I'm guessing that they use the same bolt and spacing to go onto the crankshaft, whether you have the 1.0 or even the 1.5.
For the 1.5 there are nice lightweight versions, which could be interesting but I don't have a 1.5 engine. If they are interchangeable they could be used.
I would like to have a lightweight pulley that also does underdrive, I think 10% is acceptable. I found something about NST underdrive pulleys but they are no longer supplied?
So, can I use pulleys from all Yaris engines (also newer models), and perhaps more Toyota engines?
For older and newer Toyota performance engines (from 4A-GE to 2ZZ) you can find all kinds of lightweight pulley sets. Do they all use the same bolt to bolt onto the crankshaft? Then it is only the size and belt width that is left, to compare.
Same questions go for the alternator and waterpump, they are probably very similar amongst all vvti engines?
Swing is offline   Reply With Quote
Concerns about pulley's Black_griffin6 Performance Modifications 35 02-04-2012 12:05 PM
Pulleys, pulleys, pulleys! Deltasix Performance Modifications 15 03-21-2009 11:10 PM
Greddy TI-C, NST Pulleys, etc. drkmcc Items for Sale by private party 12 02-12-2009 06:05 PM
Drift Yaris + NST Pulleys = :) thefoth Performance Modifications 20 11-20-2008 09:03 PM
NST Pulleys hatchbackkid82 Performance Modifications 15 09-29-2007 08:04 PM
