Old 05-05-2018, 03:10 PM   #1
komichal
Changing AC pressure sensor
Hi folks,
my AC sometimes takes 5-10 minutes before it starts blowing cool air (but it is like 1 case out of 5).
Local AC service center inspected the system, found nothing extraordinary (they measured the pressures - all OK, they had to add some "freon" as well but just a little). But they do not have TechStream so they could not check the data there.
But I do have TechStream so I noticed that the readings from the pressure sensor are a bit erratic whenever the AC problem happens. So I am going to change that little thing.
I have read probably all the topics around it here on yarisworld - guys you are awesome! Now I know I have to get myself one piece of 499000-7141.
The last thing is the change itself. I have learnt on the internet that "most cars do have a ball valve on that sensor so it can be replaced without evacuating the AC system". Is it also the case for Yaris? (2007 5-door 2SZFE 1.3 64kW) Or do I need to drop by the local AC shop one more time to do the change for me? Or if I am fast enough, can I replace the sensors with just a little bit of hisssssssing from the line that may have no impact on the functionality, especially when it was recently topped up?
Thank you in advance, lads!
DIY : changing the Oxygen / O2 sensor on Yaris hatch MANY PICS auxmike DIY / Maintenance / Service 50 12-10-2024 12:39 PM
Help! A/C low pressure sensor..jumper? marcus Photo-Video-Media Gallery 12 07-18-2012 05:50 PM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 04:46 PM
