Old 08-02-2014, 03:10 PM   #1
momaterials
momaterials's Avatar
Drives: Yaris 2013 1.3 99 HP 6 speed
Which engine oil is best for Yaris 3rd Gen?
Hi
Please ,I own Yaris 2013 third Generation,it s 1.3 vvti 99 bhp and I would like to know about the oil engine that Toyoyta specialist recommend for the car .I use 15w40 but I have a doubt that s not excellent
thanks in advance
momaterials is offline   Reply With Quote
Old 08-02-2014, 03:16 PM   #2
nortonfb
Drives: 2007
I would think that a synthetic 5w20 or even a zero weight.
Steve
nortonfb is offline   Reply With Quote
Old 08-02-2014, 05:20 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
What does it say on the oil cap on the engine?
Old 08-03-2014, 08:22 AM   #4
bronsin
bronsin's Avatar
Or the owners manual?
Old 08-03-2014, 08:34 AM   #5
mrpj
Drives: 2014 Icon+ 1.33l Multidrive
For U.K. models, same engine, 0W20(preferred)) or 5W30 to API SL, SM or SN. It's not marked on the oil filler cap on my car. However, as you are in Algeria where it will definitely be much hotter a different, higher viscocity could well be recommended. My handbook states that both the viscocities above are fine for temperatures ranging -29 deg.C to 38 deg.C but the arrows indicate lower and higher than those temperatures.
What does it say in the owner's manual?
Why don't you 'phone a Toyota dealer and ask them what they use/recommend?
mrpj is offline   Reply With Quote
Old 08-03-2014, 01:46 PM   #6
momaterials
The car is still under warranty and usually I maintain my car in Toyota garage here in Algiers .they use the 15w40 on every oil change .in the manuel there are some explanation but I m not sure and I could not understand technical info ,that why I m looking for your advice lol
that s true the weather in Algeria is hotter than other European or american countries which involve special oil engine
the thing is that I doudt about Toyota agent using Total 15w40.I have heard and checked some websites that 5w30 is better ;improve fuel efficiency and car performance
Old 08-03-2014, 03:26 PM   #7
IllusionX
Well, you might not properly protect your engine with harsh temps like in Algeria if you go with 5w30. 5w30 is what is normally used in North America.
Old 08-03-2014, 04:59 PM   #8
bronsin
bronsin's Avatar
Ask them why they use 15-40. They may have a reason.
I doubt use the thicker oil will have an adverse impact on the engine. Offhand I would say it makes sense.
Old 08-03-2014, 06:25 PM   #9
2009D4d
Drives: 2014 Yaris Icon + 1.4D4D
Toyota list the following as acceptable for 1NR 1.33 Yaris:
20W-50 and 15W-40 API grade SL, SM multigrade engine oil
10W-30, 5W-30, 5W-20 and 0W-20 API grade SL "energy-conserving", SM "energy-conserving",or ILSAC* multigrade engine oil
2009D4d is offline   Reply With Quote
Used Oil Analysis : 2010 3 door Yaris : 4,341 mis. on oil and 16,611 miles on engine Hershey DIY / Maintenance / Service 22 08-04-2011 10:52 AM
Dealership filled engine with too much oil... posaunemeister DIY / Maintenance / Service 17 10-18-2009 11:21 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
