Old 07-21-2014, 11:15 AM   #1
Slitwrist Smile
Drives: 2008 yari sedan/2007 sc'd tC
FS: Scangauge 2
$100 shipped + buyer covers paypal fees, (insurance optional) - great condition! - no scratches on screen - I will try to find some double sided sticky tape to include (thats the best way to mount it) right on top of the steering wheel column, but below your gauges. Keeps it in your line of sight, and does not look out of place at all.
Plugs right into your OBD2 port, can change display colors to whatever color you want (to match your custom interior, or gauges, or whatever is easier on your eyes). You like bright green? Light Pink? Purple? Medium Blue? Perfect.. It'll do all those colors plus variant shades of colors.
I can't use this anymore, since my supercharged civic SI has Flashpro w/ blutooth which must remain connected to use the blutooth features.
Scangauge 2 also can check engine codes, (clear codes too), give you instant MPG figures, overall trip figures, intake ambient air temps, closed or open loop (this will boost your gas mileage through the roof if you learn to drive properly) and so, so much more.
This will pay for itself in 6-12 months after you learn to re-adjust your driving habits. I know when I used it in my yaris I was able to eek out mid/high 40 MPGs all day long using this and adjusting my driving.
This is also for sale on other forums, so its first come first serve.
I will post pictures later, I am at work making sale threads on different forums.
Comes with the gauge itself, and the cable you need. Its plug and play, and you can be up and running in less than 1 minute with this. Seriously, just plug it in your OBD2 port, route the cable behind the steering wheel, adjust your wheel so its in the lowest setting, slide cable through the small opening now created, and then re-adjust your steering wheel to your preferred setting. Take the cable, plug it into the unit, and put the unit where ever you prefer using the double sided sticky tape.
My Ebay ID is exceed192ln7 - over 710 positive transactions.
I would keep it if I could use it. But with my OBD2 port taken over by Hondata Flashpro, I have no open port to plug it into.
Slitwrist Smile is offline   Reply With Quote
Official Scangauge II Thread - Share your Data, Discuss Settings ,Problems, Findings! TRD_Yaris General Yaris / Vitz Discussion 183 02-01-2017 12:18 PM
ScanGauge Question edmscan Fuel Economy Forum 10 05-15-2013 04:34 PM
Scangauge and Imperial Gallons ? edmscan Fuel Economy Forum 1 05-02-2012 10:36 PM
scangauge II versions TinyGiant Fuel Economy Forum 1 12-23-2008 12:10 PM
FS: Scangauge II (barely used) $80 Fel Items for Sale by private party 25 12-08-2008 11:15 PM
