![]() ![]() Drives: Yaris Join Date: Feb 2013
Starter/ignition issues?
Hi everyone.
Anybody ever got this kind of problem whenever they start their car after a long rest (e.g. >7hours). It happens regularly to me in the morning and after leaving work. I have attached an audio recording of the sound I get everytime I try to start the car... http://wikisend.com/download/534598/Voice[/url] 006_20140827.m4a]Voice 006_20140827.m4a Thanks a lot for helping :) ! |
![]() Drives: 2009 3door 5-speed Manual Join Date: Aug 2014
Hmmm I have two yarises Yari? Well the one with 70k starts right up ... The one with 155k sounds like this SOMETIMES but im thinking im not holding down the ignition long enough... But maybe need to replace starter? Im not sure How many miles are on yours?
You don't need to hold the ignition to start. It works like a start button.
I can't listen to the link on tapatalk. Someone please fix the link...? |
I can't access the link so don't know what sound OP is talking about. Based on my experience, if you need to hold the key in the 'On' position to start the car, your battery is on its way out.
![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
Heres the link fixed: http://wikisend.com/download/534598/...6_20140827.m4a
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
is that the actual car making that noise or is that an old chevy V8? Doesn't sound anything like a toyota trying to start.
I just listened to the audio. I suspect a dying battery.
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
Hi Guys.. .thanks you for trying to help.. !
I don't think it is a dying battery since my battery is two years old. I suspect it may be the ignition...still trying to sort this out this week...hope anybody who ever got this issue can shed some light |
You say it only does it after a while the car has been sitting there. I can't see it being anything else than a bad battery.
Static drain on the Yaris is quite high, so 7 hours could be just that to drain enough that it doesn't start very well. Go get your battery tested. I just changed a battery on my in-law's pathfinder. Mechanics tested it to be defective, after less than 2 years i've put that in. |
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
This was posted in the wrong section, moved it. Please remember to post your threads in the correct section.
| Toyota Recalls | auxmike | General Yaris / Vitz Discussion | 535 | 02-25-2021 06:13 PM |
| Auto insurance issues from modifying a Yaris? | RMcG | General Yaris / Vitz Discussion | 11 | 06-24-2012 04:38 PM |
| Just bought a 2010 Hatchback AT and having some issues | Dissolutus | New YARIS Purchase Forum | 9 | 03-19-2010 10:46 PM |
| CV joints or axel issues | aucorium | DIY / Maintenance / Service | 1 | 02-17-2010 09:10 PM |
| For the TEIN S tech users any sagging issues? | marcus | Performance Modifications | 7 | 01-28-2010 04:06 PM |
