Old 10-09-2014, 09:06 AM   #1
Janiecakes
Drives: 2008 Yaris
Check engine light
we have a 2008 Yaris sedan. We just hit 55800 miles. And the check engine light has come on. Since it came on exactly when it hit 55800 I'm wondering if anyone knows if this is way to try and get us into the dealership for some unneeded tune up. The car itself seemed to be running fine. In need of an oil change but nothing else.
Janiecakes is offline   Reply With Quote
Old 10-09-2014, 09:15 AM   #2
ajkochev74
Drives: Yaris
Loose gas cap? Did you fill up recently?
ajkochev74 is offline   Reply With Quote
Old 10-09-2014, 09:55 AM   #3
No, it is not a ploy.
As there are hundreds of codes which could be thrown, you really need to get it read. Could be evap (gas cap), O2 sensors, random misfire, just to name a few.
Old 10-09-2014, 12:54 PM   #4
alanwagen
see it all the time
I see it all the time where people at the pump will top off their gas tank which causes the evap system to fail.
Let us know when you find out what it is.
Old 10-10-2014, 03:14 PM   #5
harda toenail
Drives: Want a yaris
Run by autozone. They will give you a code readout for free. Post the code on here and we can help you out
harda toenail is offline   Reply With Quote
Old 10-10-2014, 09:17 PM   #6
Jlively
Mr J.
Drives: 2009 yaris 5 dr HB
Send a message via AIM to Jlively
Is it the CEL or is it the Maint Req light? Maint req is not a CEL and does not throw codes according to the dealership. That is for their recommended oil changes, filter changes etc. If it is in fact a CEL then you need to have someone run a scanner on it and see what code(S) are being thrown. Maint req lights are easy to reset and take off, the CEL you ofc would have to fix w/e it is throwing the code then it'll go away.
Jlively is offline   Reply With Quote
Old 10-11-2014, 10:14 PM   #7
nookandcrannycar
You're as cynical as I am
Old 10-11-2014, 10:20 PM   #8
nookandcrannycar
I guess I'm just lucky. I've been topping off ever since I got my learner's permit, and I've never had to replace any fuel related parts on any vehicle .
Old 10-11-2014, 11:57 PM   #9
IllusionX
Drives: 07 Yaris Sedan Aero
By topping off as in filling up until you see gas at the cap. I never top off that much. First click and maybe add 1 or 2 more litres.
Old 10-12-2014, 09:47 AM   #10
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
After the first click, I just round it off to the next dollar
nobodywise is offline   Reply With Quote
Old 10-13-2014, 12:45 AM   #11
nookandcrannycar
Filling until I can see gas in the neck. I know that = 12.777 U.S. gallons because I once ran out of gas as I was pulling into a gas station (). When CTScott figured that the maximum capacity of the tank is 12.8 gallons, I knew this was correct because: 1. It's CTScott, and 2. Because of my 'running out of gas while pulling into a station' experience.
Old 10-13-2014, 01:10 AM   #12
nookandcrannycar
There was a past thread where one of the main questions was (I'm paraphrasing) - 'Is the click an unfailingly reliable 'set point' for figuring MPG (will it ALWAYS happen in the same place), or can some sort of malfunction cause a difference. CTScott weighed in with at least one scenario/malfunction that could cause a difference, and (IIRC) others did as well. I've always applied 'my style' (filling until I can just see gas in the neck), so that thread confirmed that my quest for accuracy and consistency (however picky and 'OCDish') has some concrete basis. I suppose if I ever had a fuel related part fail on a car I might reevaluate 'my style'...but I can't think of anything else off the top of my head that would compel me to do so.
Old 10-13-2014, 04:47 AM   #13
alanwagen
why risk it
It may be just a matter of time before you foul your canister. But actually there are more reasons to NOT top off your tank. You can Google them but this one here seems very convincing.
http://www.epa.gov/donttopoff/
help..check engine again dindy DIY / Maintenance / Service 12 12-13-2012 07:17 PM
Cold air intake....check engine light on...??? JohnnyMalice Performance Modifications 4 04-29-2012 10:46 PM
Differntial diagnosis for the check engine light yaris sedan dante2086 DIY / Maintenance / Service 1 12-18-2010 10:04 AM
Got engine check light :( jmew0ng DIY / Maintenance / Service 15 07-01-2009 11:09 PM
