Old 11-03-2014, 11:41 PM   #1
TheJage
Drives: 2007 Yaris
2007 Yaris Sedan Radio Wiring Help
Hey there,
I have a 2007 Yaris Sedan.
I have read most of the posts on here about wiring an aftermarket stereo and the wiring diagrams, but I am still confused. When I pulled the stock unit out, there were 3 connections to the stereo.
First had the wires:
Yellow
Black
Red
White
Green
Second:
Grey
Yellow
Black
Purple
Pink
White/Black
Blue
Green
Grey
Third:
Red
White
Red
Grey
Green
Everything I have read says:
12V = blue, Ground = white/black, Ignition = grey, Illumination = green, Antenna = Black, LF = Pink/Purple, RF= Grey/Yellow, LR = Black/Yellow, RR = Red White.
Is it just me or do these not match up? It seems I need wires from all 3 connections, but then, what are the extra wires for???
It may have been a bad idea, but I already cut the connectors getting ready to splice the wires onto my new stereo.
Please help! Thanks.
TheJage is offline   Reply With Quote
Old 11-04-2014, 06:18 AM   #2
The third connector is for the AUX jack.
Old 11-04-2014, 10:19 AM   #3
TheJage
Drives: 2007 Yaris
Thank you! So it seems I do not need to use the wires in the third connector? But still, there is an extra green wire in the first connector. Anything this should be connected to?
And I assume the first connector is for the rear speakers while the 2nd is for everything else?
Thanks again for any help. It's my first time doing this.
Old 11-04-2014, 11:12 AM   #4
There are actually two greens. The one in pin 5 of the 6 pin white connector is ILL- and the one in pin 10 of the 10 pin blue connector is ILL+.
ILL+ is can be used for radios that have a dimmer input to tell it to dim down when the headlights are turned on.
Old 11-04-2014, 11:31 AM   #5
TheJage
Drives: 2007 Yaris
You're the man! Thanks.
Replacing a Center Armrest? (2007 Yaris S Sedan 4 dr) reeser07 DIY / Maintenance / Service 3 08-01-2014 04:28 PM
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
2007 and up Yaris Sedan S McDizzle New YARIS Purchase Forum 3 12-03-2009 01:42 PM
