Old 11-17-2014, 06:58 PM   #1
blackace4
Drives: 2007 Yaris
Low Beams do not function
My 2007 Yaris Hatchback has a problem. My day running lights do not come on, and low beams also do not work either. My high beams come on when I move the control arm is in forward position as well as when I pull the lever towards me. When the lights are turned in the on position the little clear bulb comes on only but not the low/high beam combo bulbs. Also the blue high beam light does not illuminate anymore on the instrument panel. Turn signals, rear lights, etc are all fine . Do I simply replace the bulbs? My daughter noticed 2 days before this happened the right side bulb was not on when the other side was during daytime running position. When she turned to low beam position it worked.
blackace4 is offline   Reply With Quote
Low beams & High beams on together? Deathegg DIY / Maintenance / Service 26 12-22-2018 11:19 PM
Low Beams not working Karri'es Yaris DIY / Maintenance / Service 7 02-10-2012 09:34 PM
Problem with low beams and High Beams thebarbrr DIY / Maintenance / Service 7 09-22-2010 09:43 AM
Fog lamps as back up low beams. ellenbetty General Yaris / Vitz Discussion 114 10-22-2009 04:40 PM
