![]() ![]() Drives: 2013 Yaris LE 5Dr Join Date: Nov 2014
vent selector switch seems stuck/difficult to turn
Anyone have this problem? It's really difficult to turn and on a cold morning it's nearly stuck.
Looking for fun! |
That is a common issue and often results in snapping the cable or popping it off the back of the knob. Pull the glove box and check the vent selector (the other end of the cable) while rotating the knob. There is a clear plastic grease on it that may be gone, or it may simply be that there is some moisture in the air box that is freezing the flappers in place. For that there is not much you can do, other than wait until it warms up to change the output position.
My car is covered under a comprehensive warranty still, I'm probably just going to take it to them.
The switch also seems sunken in. Like, its about half and an inch shorter than the rest of the switches.
Looking for fun! |
Here's a photo
Looking for fun! |
I assume that's not normal?
Looking for fun! |
![]() Drives: 2010 Toyota Yaris Join Date: Nov 2014
Mine is very stiff when cold, I just try to warm up car before i move it.
Does anyone else's first switch sit more inward than the others like in my picture? I'm concerned that's not normal.
Looking for fun! |
That is not normal. Either the tabs that lock it into place broke or have just popped free.
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
Dealer says it isn't covered under warranty, but hasn't done anything, they just looked at it, called, said it's not covered, do you want it fixed. I said I was disappointed it wasn't covered and I'd get back to them.
I'm 90% certain it's a broken tab on the knob. I assume they think so too, and are thinking it's misuse/physical abuse, and that is why they don't want to cover it. The only problem being, I didn't do that, it was like it when I purchased it. Thoughts?
Looking for fun! |
| Manual Transmission Vent | tmontague | DIY / Maintenance / Service | 3 | 09-08-2022 10:09 PM |
| Sound when making a left turn (a water flow sound) | jimmydie | DIY / Maintenance / Service | 9 | 06-20-2013 05:35 PM |
| Projectors retrofit, black reflectors and dimmed front turn signals | my2sense | General Yaris / Vitz Discussion | 11 | 06-20-2012 11:39 AM |
| Are rear red turn signals planned for Yaris as well ? | 77W | General Yaris / Vitz Discussion | 38 | 02-22-2010 06:41 PM |
| Will local bay area members please stand up! | YarisSedan | California | 264 | 07-28-2009 11:53 PM |
