Old 03-05-2015, 11:28 PM   #1
Innovative 1
Drives: 2007 Yaris HB 5spd
HID's wont fire up
Got an '07 hb. Bought spec d projector headlights. Hooked everything up turned on headlights and xenon's wont fire up. Hooking up to stock harness. Got power to stock plug. Power at ballast single red connector. Some one help me please
Innovative 1 is offline   Reply With Quote
Old 03-05-2015, 11:32 PM   #2
How did you wire them? Many HID kits are not setup for the Yaris' switched ground to the headlights, as opposed to switched power.
Old 03-06-2015, 12:42 AM   #3
Innovative 1
Wired them modifying the wires on the harness that came with the headlights. 2 wires that are seperate with own plugs off ballast wired into wires off plug. Black for black and blue for red for low beams. Black for black and red for red on high beams. I have the feeling your gonna tell me what I did wrong and hopefully tell me the right way.
Old 03-06-2015, 06:28 AM   #4
Since they don't work that is likely the case.
With the headlights, black (left) and grey (right) are the positive wires. Then, green (right) and brown (left) are switched ground wires to turn on the high beams and blue (right) and green (left) are switched grounds to turn on the low beams.
Old 03-06-2015, 08:19 AM   #5
Innovative 1
So how would i wire them up to make them work? Is it possible?
Old 03-06-2015, 11:27 AM   #6
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Please post the wiring schematic (with color codes) of your SpecD projector headlights. Also, do those headlights have lighted halos as well?
Old 03-06-2015, 11:36 AM   #7
Innovative 1
They do have halos. They where pretty easy to hook up. Wired them to the small drl thats next to the stock headlight. I will also mention that I unplugged the drl module before. Didnt like having drl's. On a side note, I lived in Connecticut off and on throughout my life. Newtown and Bethel mostly.
Old 03-06-2015, 01:18 PM   #8
Innovative 1
Tried to upload some pictures from my phone but didnt work. To large of a file.
Old 03-06-2015, 11:46 PM   #9
Innovative 1
Do they make ballast that work with switched to ground?
Old 03-07-2015, 12:09 AM   #10
Innovative 1
Gray and blue low beam. Red and grey high beam on the spec d harness.
installed some 3000k HID's thebarber Photo-Video-Media Gallery 17 01-22-2010 09:45 AM
crank, fire, hesitate, crank, fire, run, gas smell twowheels General Yaris / Vitz Discussion 9 06-25-2009 07:11 PM
Dash destroyed in electrical fire. purpleminx General Yaris / Vitz Discussion 79 06-12-2009 03:53 PM
DRL and HID's? dimsum69 Cosmetic Modifications (Exterior/Interior) 5 01-12-2009 03:30 PM
NEW HIDS 10000k!!!!!! elsteverino889 Cosmetic Modifications (Exterior/Interior) 69 01-26-2007 12:12 PM
