![]() Drives: Yaris Hatchback Join Date: Aug 2006
Air Conditioner Noise
Hello everyone,
Turned on my air to the highest level today and it was making a loud noise that could be heard over the radio, I can't begin to describe this noise, but when I turned it down to 3 there was no noise. My car is an 07 HB with less that 5,000 miles. Everyone in my family is automobile challenged so there isn't anyone I can begin to ask, so I came to the experts. Has anyone experienced this or know what might be causing this? Is your air loud? I can't get to the dealer that I bought the car from until Friday, will any Toyota dealer honor the warranty? Thanks in advance, Cathy |
#2 | |
![]() ![]() ![]() ![]() ![]() Drives: 07 Bayou Blue Liftback Join Date: Apr 2007
You might want to check the AC filter access door behind the glove box. It might not closed properly. This is just a guess. If all else fails drive up to VA as I am off work do to injury for a couple of weeks.
I have a noise too.
I put circulation, press the A/C..when I'm not moving, i hear a BBBBBBBBBBBBBBBBBB...etc, whe nI move its gone...wtf is that? Only happens when I got hte A/C button pressed. The noise isn' noticeable when music is on but it happens.. -- Blen
http://www.360voice.com/tag/noobblenjar ![]() My Car http://www.yarisworld.com/forums/showthread.php?t=4245 My DJ www.PainlessWolf.com |
![]() Drives: 2007 Red Yaris RS Join Date: Mar 2007
as long as its not a loud CLICKING TICKTICKTICKTICK, thats a sign of the compressor clutch about to go, but im sure these toyota ones are designed much better than that
Is everyone using the outside air circulation vs inside air circulation when this occurs? I remember something about that in the manual. But, I might just be stir crazy from sitting around the house and just imagining the whole thing?
I use outside all times. Only use the inside when im driving in a smelly place or its really hottttttt outside, humid and need max A/C.
But my noise happen either way as long as A/C button is on. -- Blen
Thanks so much for the suggestions, I knew I could count on you guys!
Cathy |
Well im almost at 10k miles..gotta do my oil change probably tomorrow or tuesday so I'll have them check this shit out...
-- Blen
![]() ![]() ![]() ![]() Drives: 2007 Black Yaris sedan Join Date: Sep 2006
Ive used ac about 5 times,no noise,the fan is directly brhind and to the right of the head unit.Since I have a home-made ac filter,I never put the fan on 4,this may help you.
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
it's a locust
SPONSORED BY
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
Any Toyota dealership in the United States can take care of you
#14 | |
Thanks again, Cathy |
#15 |
Tired of the Stars!
WOW! Did you get the cows engine option instead of the usual hamsters? Must be hard to keep 'em fed.
Many moons ago, I worked as secretary for a small automotive/body shop and I learned a valuable lesson from the mechanics there... Does it work? if yes, is it leaking anything? if no, don't worry so much about the noise it makes! Most noises are harmless. |
#16 |
Does it work? if yes, is it leaking anything? if no, don't worry so much about the noise it makes! Most noises are harmless.[/QUOTE]
Well, I can understand that, but this car has less than 5,000 miles on it, and I live in the desert of southern California, so the air needs to work. I dealt with the air not working in my Tercel for the last 2 years of ownership, so this is a biggie for me. And unfortunately this noise is loud, couldn't probably carry on a conversation with the air on. Thanks for your advise. Cathy |
#17 |
Tired of the Stars!
I'll see your SoCal & raise you a GA in the dead of summer... wet hot trumps dry hot every time! Had a noisy AC in the last car I had, cooled like a bitch... just had to turn up the stereo! Under warranty, def get it fixed, but don't obsess about it.
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
| Cold Air Intake vs. Short Ram Intake | nevermorez | Performance Modifications | 1 | 01-24-2007 04:25 PM |
| Air Flow switch problem | aucorium | DIY / Maintenance / Service | 5 | 01-15-2007 04:54 PM |
| 1.3 Ltr Yaris Air Filter mods | aucorium | Performance Modifications | 9 | 08-18-2006 08:32 AM |
| Noise in the A/C System | cburac | DIY / Maintenance / Service | 1 | 05-16-2006 06:14 AM |
