Old 07-18-2012, 12:10 PM   #1
bigdonga
Drives: yaris 1.3 tr
yaris oil filter
hi i have a 2oo9 1.3 auto and am having trouble finding the oil filter housing and do i need a special tool to undo it, thanks for your help
bigdonga is offline   Reply With Quote
Old 07-18-2012, 10:06 PM   #2
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
With a screw driver. Create a noose put it around the filter then spin the thing tight around the filter.Then rotate the whole assembly I think it's anti clock wise.
Old 07-19-2012, 12:38 AM   #3
Lux
Lux's Avatar
Drives: NCP91
The 2NZ-FE uses a canister-type oil filter: it screws onto the engine block beside the oil sump. You will see it clearly from underneath. No special service tools required for it, but tools do exist to make removal easier.
An effective DIY/household tools method of twisting off a stubborn filter is to hammer a punch or or stake or a similarly long, slender rod into its side and unwind it. Works every time and does not rely on a friction-based strap or pliers since it could be slippery from oil.
Lux is offline   Reply With Quote
Old 08-10-2012, 03:39 PM   #4
bigdonga
Thanks for the reply but the filter on my car is an eco paper filter not the cannister type and there is no obvious housing.
Old 08-10-2012, 03:57 PM   #5
bigdonga
Old 08-10-2012, 04:25 PM   #6
The oil filter assembly on your engine looks like this:
There is a drain plug at the bottom, which you open first to empty it, and then you remove the canister to change the element (part number 04152-40060).
The wrench for removing the canister is: Assenmacher Specialty Tools TOY 640
The canister is an odd size (64.24 mm), so the standard filter wrenches don't fit (64mm is too small and 65 mm is too large)
Old 08-11-2012, 01:08 PM   #7
Geoff Peace
Drives: Yaris 1.33 litre 2011
Attachment 48064
Can I ask please. Is this the same filter and part numbers (with the same odd size for the removal tool) as on the new type Yaris (2011 year, 1.33 litre engine)
Regards Geoff Peace.
Geoff Peace is offline   Reply With Quote
Old 08-11-2012, 10:24 AM   #8
bigdonga
Thanks CTScott for your reply and the diagram both very helpful, will attempt to make the tool with a piece of pipe with two slots and a bar many thanks big donga from ongar uk.
Old 04-18-2015, 12:20 PM   #9
bronsin
bronsin's Avatar
Hmm seems like a metal band oil filter wrench should work to grab the housing and turn it counter clockwise to remove? 64mm is ~2 1/2 inches. Metal band filter wrenches typicially accommodate filters from say 2 1/4 inches to 3 1/8 inches or similar.
2 1/2 inches is pretty small for an oil filter.....
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
FS: Oil filter to suit yaris mickd Items for Sale by private party 1 11-03-2008 07:55 AM
