Old 04-28-2015, 02:50 PM   #1
gumby002
Drives: 2008 Yaris Hatchback
New Trailer
My new trailer looks like this fully loaded.
gumby002 is offline   Reply With Quote
Old 04-28-2015, 03:33 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Nice! What bits did you use for your hitch and wiring?
Old 04-28-2015, 03:47 PM   #3
gumby002
Reese Towpower 77191 Class I Insta-Hitch 1-1/4" Square Tube Receiver
Curt 56175 3 to 2 Wire Converter with Circuit Protection
The hitch take a little bit of tightening of the top bolt before the bottom bolts and its a tight fit for those with average to larger hands.
The wiring harness also requires some work. I took the driver's side rear plastic panel off part ways to get to the area i needed and then worked to the other side and just went through the opening that is provided.
Old 04-28-2015, 05:16 PM   #4
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Love seeing little cars pull big things!
Old 04-29-2015, 09:29 AM   #5
shepd
Drives: 2007 Yaris 5 door RS
Just curious, I've always pulled off the rear lights on vehicles I'm wiring up a 4-way harness to and tapped off the lights there for the converter, then hid the converter somewhere inside the paneling in the trunk area. Any reason you chose to run the wiring from the kick panel?
Old 04-29-2015, 10:43 AM   #6
Vervepipes
CowCountry Hornet Handler
Vervepipes's Avatar
Drives: '08 Sedan
Looks just like the trailer I'm thinkin gof picking up, they cost a bit more up here though, prices on them are much better in the States...
Vervepipes is offline   Reply With Quote
Old 04-29-2015, 03:06 PM   #7
gumby002
This is how i did it.
http://www.yarisworld.com/forums/showthread.php?t=54124
Old 04-30-2015, 10:19 AM   #8
shepd
That makes sense. :)
BTW: Very jealous that you Americans get those well priced Harbor Freight trailers. If I had the balls, I'd bring such a kit back into Canada (If you actually declare it, they charge 13% tax plus about $300 in inspection and RIV fees which kills the deal).
Old 05-03-2015, 09:56 AM   #9
BobTheYaris
BobTheYaris's Avatar
Drives: '08 Yaris HB 2 dr
What length trailer is that? Im looking to do the same thing, Im just not sure what length to weight ratio I should go for.
Sent from my iPod touch using Tapatalk
BobTheYaris is offline   Reply With Quote
Old 05-04-2015, 06:21 AM   #10
CrankyOldMan
Looks like this one from Harbor Freight
Old 05-04-2015, 10:52 AM   #11
gumby002
That would be the one.
Getting ready to add an even bigger (heavier kayak) to the fleet. It now makes having that even more important because I cant clean and jerk a 140lb kayak to the top of the car (besides, I think the roof would cave....).
Old 05-04-2015, 12:14 PM   #12
Upgrading soon?
Old 05-04-2015, 12:39 PM   #13
gumby002
Upgrading soon?
lol; 3 will be my max fleet on my trailer.
The 2 you see and a 2012 Hobie PA 14 (likely addition). Its a big heavy beast, but I cant pass up the price vs what i'm getting for the price.
fnkngrv's custom trailer build log fnkngrv Off-topic / Other Cars / Everything else Discussions 5 10-12-2012 01:24 PM
Connecting wiring to small trailer charles nelson DIY / Maintenance / Service 8 04-24-2012 05:39 PM
Trailer hitch wiring yaris 2012 Strider199 Third Gen Yaris General Discussion 16 04-15-2012 07:00 PM
'07 Yaris LB Hidden Hitch and Trailer Pics Z00KA General Yaris / Vitz Discussion 18 04-13-2012 10:40 AM
Driving w/ Trailer Safety Connoisseur_of_fine_cars General Yaris / Vitz Discussion 2 11-03-2011 06:00 PM
