Old 06-19-2015, 02:23 AM   #1
SeattleCommuter
Drives: 2007 Toyota Yaris sedan
Help! sheared bolt on engine
While trying to replace the thermostat on my 2007 Yaris sedan, I overtightened the nuts and the bolt on the engine sheared off. How do get the broken bolt out of the engine? Can it be removed from the outside by heating it with a torch and using vise grips on the remaining bolt stub?
Or, can I weld a new bolt onto the stub and add some washers?
SeattleCommuter is offline   Reply With Quote
Old 06-19-2015, 05:55 AM   #2
If that much is left, you should be able to get it out with vice grips.
Old 06-19-2015, 09:20 AM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
x2
Old 06-19-2015, 01:19 PM   #4
SeattleCommuter
So there's not a bolt head on the inside of the engine then? I'll try vice grips.
Originally Posted by Bluevitz-rs View Post
Those are only like 6.6ft/lb. Just snugged basically. So in order to break them, they were WAY too tight.
Yes, I way overtightened the nut by mis-reading units on my torque wrench
Old 06-19-2015, 06:18 PM   #5
Correct - Those are threaded studs, so on the end they have a tiny external torx head that you use a "E#" socket to remove.
Old 06-20-2015, 08:37 AM   #6
bronsin
bronsin's Avatar
I very seldom use a TW in 45 years of wrenching, but when I do, its my circa 1970 Sears beam type with a pointer rod that twists and points at a scale.
My Dad bought a factory rebuilt short block for a 69 Beetle he bought for me to fix with a blown engine. ($400) The first thing I did was drop a washer down the distributor drive shaft hole. I started taking the engine apart to get the washer.
After 10 minutes of that my friend Peter showed up, having heard about the rebuilt engine we were getting and wanting to see me put it in. When he saw me taking it apart he laughed and said "Here help me pick it up. Now turn it upside down and shake it."
The washer fell out!
Old 06-20-2015, 08:39 AM   #7
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Great story!!
Old 06-19-2015, 09:22 AM   #8
Bluevitz-rs
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
Engine Delayed Start - Toyota 1NZ-FE 1.5L SL Runner General Yaris / Vitz Discussion 9 07-23-2011 03:13 PM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
