![]() Drives: 2010 Yaris 3 Door Join Date: Jan 2013
NEED help QUICK with alt bracket
When trying to tighten a nut on the upper part of the alt bracket it snapped and left what seems like a bolted in bolt ( trying my best to explain but you'll see in pic with red line. Anyone have any idea the name of this bolt that goes into the engine, It looks like i could get it out because there's a nut holding it down to the engine.
There is not a nut on the inside. That is a bolt which has threads on both sides of the hex head that sits against the block. I can't seem to find it in the parts catalog.
do you think that bolt is available for purchase?
Yes. As long as the parts department person can find it. Some parts are really tricky to find in the EPC.
Just took a look in the catalog online, nothing..
If you can get it out, you can simply use a bolt with a few washers to replace it.
| Micro Image Short Shift Kit DIY | jpmck03 | DIY / Maintenance / Service | 17 | 02-24-2014 07:57 AM |
| The MI SSK "Not a Big 'Car Guy'" Review | jpmck03 | Performance Modifications | 36 | 09-19-2013 11:41 PM |
| Trying to find a H/O alt | Slick | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 09-16-2009 03:24 PM |
| How much does the Weapon R seat bracket weigh? | schleppy | Cosmetic Modifications (Exterior/Interior) | 4 | 04-13-2009 03:59 PM |
| Quick advice needed on unfinished amp install | GreenSpeed | In Car Entertainment + Electronics (audio / video / alarm) | 15 | 01-15-2009 11:03 PM |
