Old 10-24-2015, 06:11 AM   #1
lormagni
Drives: Toyota Yaris 1.33 SR
Removing lower rear spring perches?
Hi guys, just had my Vogtland lowering springs installed two weeks ago after removing the Eibach ones that were too harsh to ride on. I noticed that both springs sets tend to leave the car higher in the rear (my wheelgap is two fingers in the front and two and half/three in the rear). I was thinking about removing the lower rubber perch in the picture below to make the car sit lower in the back. Is it possible or this will cause too much rattling/noise/damage?
lormagni is offline   Reply With Quote
quick fix for bent rear axle/ hub? (please advise!) tylerwatts53 DIY / Maintenance / Service 6 07-16-2014 07:20 PM
Rear spring swap info The Spectacle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 02-22-2009 09:37 PM
ideal spring rates for coil-overs on Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 30 01-27-2009 04:24 PM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 09:26 PM
