Old 08-18-2015, 04:21 PM   #1
Kar98
Drives: 2011 Scion tC
Hey, did you know batteries could boil over?
I think the 100*F and above for weeks on end, A/C running at full blast most of the time may have been the culprit here.
Oh, and it was a little bit under spec anyway. The last one died under similar circumstances at the same time of year two years ago. Yay for two year replacement warranties without receipt. Had to pay $30 difference to get the right sized one this time, and installation is free if you do it yourself.
I'll fix the tie down when I get home...
Old 08-18-2015, 05:15 PM   #2
shepd
Drives: 2007 Yaris 5 door RS
Batteries usually "boil" (gas separation) when they are being overcharged. If they boil excessively, they're being severely overcharged. I would suspect an issue with the alternator!
Old 08-18-2015, 05:18 PM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Exterior temps should not be affecting your battery boil point. t and outgassing like mentioned above. I would definitely recommend having a diagnostic run on the entire charging system.
Sent from my SCH-I545 using Tapatalk
Old 08-20-2015, 06:39 PM   #4
BLH
Drives: 2007 Yaris Sedan
Also be very cautious with anything that could cause a spark.
Some of the gas it is boiling off maybe explosive.
I didn't have an overcharging problem.
I did have a low water issue in a battery in an Escort. I went to start it and there must have been a spark between the exposed plates. Boom acid all over the place. Peeled the paint off of the inside of the hood.
BLH is offline   Reply With Quote
Old 08-21-2015, 06:08 AM   #5
bronsin
bronsin's Avatar
Yeah my daughters 12 Camry apparently had an overcharging issue. She drove it 80k miles in 2 years. There was corrosive fuzz all over the battery and adjacent fuse box and computer.
You really want to be looking at your battery/cables every oil change...
Old 08-21-2015, 07:36 AM   #6
fnkngrv
fnkngrv's Avatar
Now why would anyone want to perform preventative maintenance?
Old 08-21-2015, 11:30 AM   #7
nookandcrannycar
Old 08-21-2015, 05:51 PM   #8
Yaristeve
Drives: 3-door hatch
Don't mean to pile on but I agree with everyone above, especially about having electrics checked since this is the second time. Oh, and yeah, you were lucky it boiled over but did not explode.
It's been 100+ here and I leave my AC on all the time as well. I even drove to Vegas a couple weeks ago (3hours non-stop with AC blasting) where it was way above 100 and didn't have any issues.
Old 09-24-2015, 03:57 PM   #9
Kdaddy81
Drives: 08 yaris sedan
My wife's Yaris does this constantly. I clean it re protect it and the next oil change its back...
Kdaddy81 is offline   Reply With Quote
Old 09-25-2015, 06:24 AM   #10
bronsin
bronsin's Avatar
I coat the battery terminals liberally with wheel bearing grease.
Old 10-05-2015, 11:39 PM   #11
SirDigby
Drives: 2007 yaris 3 door
i'd suspect that garbage wallmart battery first. yuck!
Hey everyone...Did anyone get a FIX for the Oversteer Problem at fwy Speeds under war jay cobbs General Yaris / Vitz Discussion 0 06-13-2012 10:10 AM
Braille Lightweight Batteries... info/reviews... NonStopTuning Performance Modifications 73 07-16-2009 04:05 PM
Hey! Newbie here! yarissr57 Off-topic / Other Cars / Everything else Discussions 14 04-25-2009 01:41 PM
hey hey hey look what i did. thewifesyaris Performance Modifications 25 09-21-2006 12:13 AM
Toyota plans hybrid that runs on batteries hhcchen Off-topic / Other Cars / Everything else Discussions 2 07-22-2006 01:35 AM
