Old 04-18-2007, 07:32 PM   #1
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
Routing XM Antenna Wire
Is there any existing point in the firewall (rubber plug, etc) that will allow me to route my XM antenna wire without drilling?
Thanks in advance!
blacksan is offline   Reply With Quote
Old 04-18-2007, 08:28 PM   #2
Grindstone18
Grindstone18's Avatar
Drives: 07 Yaris Liftback, 90 Saab 900
You could mount it in the back behind the radio antenna and run the wire through the hatch's weather stripping then under the side panels. Takes like 10 mins. Looks clean too.
Grindstone18 is offline   Reply With Quote
Old 04-18-2007, 08:28 PM   #3
saue1436
Drives: 07 sedan
why are you putting an antenna wire through the firewall????
saue1436 is offline   Reply With Quote
Old 04-18-2007, 08:35 PM   #4
blacksan
blacksan's Avatar
I mounted on the leading edge with my Tacoma and it worked well as it was the shortest path. I am not stuck on this location, just wondering.
Old 04-18-2007, 08:33 PM   #5
blacksan
blacksan's Avatar
Cool, any pics?
Old 04-18-2007, 08:42 PM   #6
Grindstone18
Ahh, cameras dead. Ill charge it and prolly get a pic tommorow. It's raining too.
Old 04-18-2007, 08:45 PM   #7
07typeS
07typeS's Avatar
Drives: 2007 White Toyota Yaris Type S
Send a message via AIM to 07typeS
I put mine in between my rear speakers on the backdash......works through the glass, tint, radio antenna just fine..
TRD Springs w/ KYB Struts and Shocks, Custom CAI w/ K&N filter and pre filter wrap, Weapon R Header, Stock 15 inch alloys, Dezod Performance pads, Tanabe Front Strut Bar, 35% front door Tint and 20% Rear doors back Tint, De-Badged Ass, Custom painted flat black interior, Pioneer deh-p6700bt w/ IPOD hookup, Infinity components up front with custom mounted tweeter, Inifinity 6x9's out back, 1 12" kicker comp cvr........
07typeS is offline   Reply With Quote
Old 04-19-2007, 02:33 PM   #8
Grindstone18
a couple pics of mine
I <3 XM
Old 05-03-2007, 11:32 AM   #9
Imagine
Insert sarcasm here.
Imagine's Avatar
Drives: 2009 Black Pearl Sand 3Dr
Have you tried the Roady through the AUX port? I'm curious is that works better then FM. I get a lot of interference in my area from something.
Imagine is offline   Reply With Quote
Old 05-03-2007, 11:34 AM   #10
blacksan
blacksan's Avatar
I drove up too Crutchfield (30 minutes away) and picked up a ground loop isolator for my Aux input. The XM now sounds like a CD.
Old 05-03-2007, 02:08 PM   #11
Imagine
Imagine's Avatar
Nice! How does the ground loop isolator install? Wouldn't happen to have any pics would you? All of the GLIs Ive seen have been RCA style connection. Is that what you have also?
Old 05-03-2007, 03:20 PM   #12
spkrman
Drives: 1
I replaced my standard antenna with the sirius antenna, looks much better.
Old 05-03-2007, 03:43 PM   #13
blacksan
blacksan's Avatar
http://www.crutchfield.com/S-CNrBgJZ...op&i=127SNI135
Old 05-03-2007, 10:57 PM   #14
Imagine
Imagine's Avatar
Awesome thanks, I hadn't seen a 3.5mm GLI.
Old 05-04-2007, 09:28 AM   #15
Imagine
Imagine's Avatar
I installed my roady last night without the Aux cable. It seems to be better quality on FM then my Explorer was for some reason. I'd still like to try the cable though. I ran XM directly into my Alpine unit in the Civic and the quality was amazing.
Old 05-10-2007, 09:45 PM   #16
OtownYaris
OtownYaris's Avatar
Drives: Meteorite Yaris Liftback
Send a message via AIM to OtownYaris Send a message via Yahoo to OtownYaris
Is there something you can buy to put under the magnetic antenna? The antenna left marks on my roof on my last car. I don't want to install an XM antenna on top of my new Yaris if its going to screw up the paint.
OtownYaris is offline   Reply With Quote
Old 05-10-2007, 11:56 PM   #17
blacksan
blacksan's Avatar
I just waxed the antenna mounting point about once a month on my previous vehicle and did not have any problems with the finish.
Quality Shorty Antenna HB fazali Cosmetic Modifications (Exterior/Interior) 11 09-14-2007 11:53 AM
OEM Foglight Red Wire Controversy razzorjet2 DIY / Maintenance / Service 5 04-18-2007 08:01 AM
What's the difference in the Door lock Kits (wire and rod) mgthompson General Yaris / Vitz Discussion 5 03-19-2007 01:29 AM
Illimuination wire KSIbucky DIY / Maintenance / Service 2 10-15-2006 08:05 PM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 01:05 PM
