![]() ![]() Drives: 2007 Toyota Yaris Hatchback Join Date: May 2006
Dropped battdry hook inside engine bay
I was changing out the battery and the hook that secures the battery dropped inside the engine bay. I looked and couldn't see where it dropped to. How worried so I be about it rattling around if I can't find it? Would I be able to go to auto parts store pick it up or do I need to go to the dealership? What about driving around without the end hook temporary?
It is a Toyota specific part. My biggest concern would be driving over it and having it poke into a tire. Check on top of the tranny. If you remove the battery and the battery pan you should be able to find it.
I still cannot find it after removing the battery and the pan. It's weird because there almost seems like a perfect spot where it could have dropped through to the ground, yet I can't find it, unless it rolled off somewhere l I can't find it. I even moved my car hoping it might drop out.
What about the driving around without the battdry being secured. Safe? |
#4 | |
Did you check on top of the plastic panels that go to the bumper?
![]() ![]() Drives: Yaris '05 1.3 Hatch "R.I.P." Join Date: Aug 2014
I once dropped a fuse down there and literally found it a week later just lying there on the gearbox. The stuff can seriously disappear. Like "sex" said, maybe take off the front bumper and it might just be lying there **
The good news is that you can go into your local auto parts store and pick up a battery hold down kit. I went to Canadian Tire and got the 10" (25 cm) for $6.49 before tax. There's a shorter 8" one, but the 10" is the right size. Each kit comes with 2.
The bad news is I still haven't found the original, though I do think it did fall into the panels underneath the bumper. Not directly behind the bumper, but past it. So, without being able to safely lift up my car, I'm not able to access to where I think it is. |
#8 | |
![]() Seriously the important thing is to get that battery tied down so it doesn't come loose and cause more problems.
Yeah, the battery is nice and secured now.
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
| Dumb Question about air coming from engine bay | duendeverde | DIY / Maintenance / Service | 7 | 01-01-2015 12:12 PM |
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| in cabin or in engine bay | gwasabi | Performance Modifications | 4 | 01-09-2009 11:15 PM |
| Engine bay prettification project | eTiMaGo | Cosmetic Modifications (Exterior/Interior) | 14 | 04-23-2007 04:22 PM |
