Old 10-15-2015, 05:49 AM   #1
Vitz_Q8
Vitz_Q8's Avatar
Drives: 3dr NCP90R
PG Hub spacers group buy
Hello everyone,
I've contacted Penguin Garage regarding the rear spacers since Garm is not working on MicroImage any more. Unfortunately they haven't done a run for a while, but they said if there is enough demand they might make a run. I've seen couple of people here asking about the spacers so hopefully we can make it happen. If you don't know about PG spacers here's some info:
The rear hub spacers come in both 10mm and 13mm sizes and come with everything needed to install.
They will work on all Toyota Yaris (NCP91) and Scion xD.
Rear hub spacers attach between the hub and the rear axle and widen the rear track of the car. Hub spacers have the following benefits:
-Wider rear track increases handling
-safer/easier to install than wheel spacers and maintenance free
-provide a more aggressive stance
-eliminate the need for longer wheel studs (unlike most wheel spacers)
These rear hub spacers come complete with everything needed for correct installation including:
-2 6061-T6 aircraft grade aluminium hub spacers (10mm or 13mm width)
-8 Class 12.9 socket head capscrews
-8 Hardened washers
-1 Packet of anti-corrosion compound
check here to see how they look:
http://www.yarisworld.com/forums/showthread.php?t=37483
Please post here and let others know, Penguin Garage will be following this thread to gauge the interest.
Vitz_Q8 is offline   Reply With Quote
hub spacers, penguin garage, scion xd, vitz, yaris
