![]() Drives: yaris Join Date: Dec 2015
transmission wont go into OD
Hello
I have a 2008 yaris that wont go into OD. I am getting a p0717 code. Input/turbine speed sensor no signal. I understand that it wont shift into OD until the car is warmed up. that doesnt seem to be the issue. I have 2 wires that do not seem to be connected to anything any ideas what they are?? I was also wondering if anyone could tell me where the coolant sensor is in the pictures I was curious what those wires are for and what they are supposed to connect too also is there a place I could down load a wiring diagram of the car thanks |
The violet/blue wires on the connector on the left are supposed to be plugged into the VSV Purge valve which is a grey block with hoses coming out of it that should be mounted to that L shaped metal bracket on the left.
The turbine sensor on the tranny is the black one with the 2 pin connector plugged into it just behind where the tranny dipstick enters.
thank you!!!
any other insights you might have? Im trying to avoid taking it to a toyota dealer which is 3 hours away |
The sensor is likely the issue, as the code points to it and it would indeed prevent the tranny from going into OD.
| How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 09:07 PM |
| My 2010 yaris is on its 4th transmission!! Help please | Uzairlexus | DIY / Maintenance / Service | 12 | 07-16-2013 10:46 PM |
| Transmission & Reverse | Twistoffate0817 | DIY / Maintenance / Service | 4 | 08-28-2012 06:50 PM |
| Do I need a transmission flush at 57K miles if 07 Yaris should last until 100k? | lejulie | DIY / Maintenance / Service | 14 | 10-23-2011 07:43 PM |
