![]() Drives: Yaris Verso/ Fun Cargo Join Date: Jan 2015
Shifting Problems Automatic Transmission
Hello this is my first time posting here. I was hoping to get some help with my car. I drive an automatic 2000 Toyota Fun Cargo(Yaris Verso). Recently while driving in D(drive) the 2nd gear light came on along the D (drive) light. Now even when the car is in Park the 2nd gear light remains illuminated. The main problem is, the car will now only shift between first and second gear no matter the gear I put it in. Does anyone know whats going on?
Thank you in advance for any help! |
Check the connector on the assembly which the shift cable pushes. That switch assembly feeds the ECM the info on which gear is selected. If the switch assembly is bad or there is corrosion on the connector it may be telling the ECM that two things are selected at the same time.
Just to update. It was a bad SLT solenoid.
![]() ![]() ![]() Drives: 2007 Toyota Yaris Hatchback Join Date: Sep 2012
Curious, how much did it cost you to replace? Did you go to a garage or DIY?
| How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 09:07 PM |
| Automatic Transmission to Manual | Zarkos | Performance Modifications | 3 | 05-22-2014 12:24 PM |
| Automatic or manual transmission | bentjazz | Fuel Economy Forum | 31 | 03-03-2011 01:52 AM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
