Old 03-23-2016, 01:08 PM   #1
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
How to disconnect my alarm.
My Yaris alarm keeps going off at the middle of the night without any reason what so ever!! I don't want to piss my neighbor off. Is there a way i can unplug it.
Old 03-23-2016, 01:47 PM   #2
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
I'm sure there is a way to disconnect it, via fuse or something, but depending on the type of alarm it is, you may be able to program it to disable without having to go that far.
I have a K.A.R.R. security system installed by Toyota. There's a small fob looking thing mounted below my steering wheel column that lets me program it to valet mode, off, etc. If you know what type of alarm you have and find a little programming fob for it, you might be able to get results that way.
I'm assuming this is an auto arming system and don't need to tell you to simply not arm it at night lol.
Old 03-24-2016, 10:57 AM   #3
thetut
Drives: 2007 4dr sedan
The most common cause for unintended alarm trigger is the hood (bonnet) switch.
It can be either that the switch is intermittent or the rubber cap has deteriorated far enough so as to not allow full depression of the switch.
I would start there.
thetut is offline   Reply With Quote
Old 03-24-2016, 05:15 PM   #4
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
If you can find the people who installed the alarm or the manufacturers ask them if the sensitivity can be adjusted.
Many alarm systems have movement sensors that are meant to trigger if an attempt is made to tow the car. If these are too sensitive, they can be set off by a gust of wind or even by a cat jumping on the car. There can also be Glass breakage detectors that are meant to trigger on the sound of a window being broken that can also be way too sensitive.
I used to live near Kingsford Smith (Sydney) airport, directly under the flight path. The sound of a jet taking off overhead would often trigger car alarms in the street.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Disable the stock (?) alarm so I can safely reconnect the battery frankienap In Car Entertainment + Electronics (audio / video / alarm) 3 01-19-2016 11:59 AM
How to disconnect the ALARM? junorico24 DIY / Maintenance / Service 3 12-13-2015 07:39 AM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
How to disconnect horn from alarm ??? Yawesh General Yaris / Vitz Discussion 5 02-19-2009 06:12 PM
