Old 04-27-2016, 08:40 AM   #1
Carquestions
Drives: 07 Yaris
Belt Squeal mystery solved
I did some testing on a Yaris I've been working on for a while and may have come up with a solution for the belt squeal - If you have replaced or tightened your belt and are sure there are no bad pulleys etc and you still have the squeal try the "turn key slowly" trick like in this you tube video - https://youtu.be/HRrVMtyIqIY
Carquestions is offline   Reply With Quote
Old 04-27-2016, 12:28 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
3 min of my life that i will never get back , just replace your belt and have it adjusted right.
Old 05-02-2016, 03:02 PM   #3
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Man lol you pull no punches.
Old 04-27-2016, 12:54 PM   #4
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
I found replacing my a/m belt with an OEM belt, fixed my squealing problems.
brushforhire is offline   Reply With Quote
Old 04-30-2016, 03:36 PM   #5
zoidberg444
zoidberg444's Avatar
What brand is the OEM belt? I had a Dayco belt which was squealing for no reason. Even when it was a adjusted a little tight. I swapped it with a Blue Print one i found on ebay which has shut it up for now but i don't know what the quality of those belts is like. The Dayco one was fine for 18 months until it started squealing.
Old 04-30-2016, 06:43 PM   #6
CoryM
Drives: 2009 5-door, 5-speed
Dayco belts tend to be noisy. Avoid them and Goodyear. Not sure who OE is, but probably Bando or Continental. Those, along with Gates, are probably the best belts.
Old 05-02-2016, 11:04 AM   #7
bail_w
Drives: 2007 Toyota Yaris LB
Same thing happened to me when i was using the Dayco belt. I had to replace it with a bando one and so far so good after 5k miles.
bail_w is offline   Reply With Quote
Old 05-04-2016, 05:27 AM   #8
Mongoose7
Drives: 2007 Yaris HB
I too thought this post was a joke.......but I tried it (just for giggles), and it actually works just like it shows in the video!!!!! Try it if your belt squeels, as weird as it sounds, it works!!!!
Mongoose7 is offline   Reply With Quote
New TSB - 2006-2015 Yaris Drive Belt Squeal Noise on Cold Start CTScott DIY / Maintenance / Service 12 03-24-2015 06:19 PM
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
Squeal from Engine after replacing Water Pump and Serpentine Belt vidfan DIY / Maintenance / Service 7 06-24-2014 10:41 AM
Drive belt squeal at idle. junorico24 DIY / Maintenance / Service 22 03-29-2013 09:27 PM
MPG Mystery SOLVED! otterhere Fuel Economy Forum 64 12-13-2008 08:43 AM
