Old 06-27-2017, 09:04 AM   #1
MatthewMenze
Drives: 2012 Toyota Yaris Hatchback
Strategies for Reducing Engine Play
Hey All,
It seems like the motor mounts in my Yaris are made of silly putty. I was wondering if anyone else has experienced this, and if so, what modifications have you made to reduce the play without adding a ton of vibration?
In the past I have filled motor mounts with window weld or similar, and added inserts. I imagine that would work just fine here as well, but I would like some input on which mounts make the biggest difference. I don't want to fill all of them on this car, and end up with tons of vibration, but I would like to be able to shift quickly without the engine rocking around like freebird is playing.
I have also heard there is additional/better mounts off higher trim level/TRD Yaris I can get and add, but I can't find any concrete info on it.
Thank you!
Matt
MatthewMenze is offline   Reply With Quote
Old 06-27-2017, 09:42 AM   #2
tmontague
tmontague's Avatar
I bought 80A polyurethane from online and properly filled all my mounts (except for the passenger side fluid mount). I do have more nvh but I'm happy with it and it was easy to do. Just take a while to cure so your best bet is to buy new mounts and fill those then install.
http://www.energysuspensionparts.com/diymmi
Old 06-27-2017, 12:31 PM   #3
MatthewMenze
What mounts are on a Yaris stock? I can't seem to find out if there is a dogbone on base model Yaris, or if that is only at the higher trim level.
If there is a dog bone, I would like to try filling that first.
Old 06-27-2017, 12:50 PM   #4
KTS
KTS's Avatar
Drives: Vitz RS
This is what i did for the rear mount. Cannot complain. There is some vibration but your passengers wouldn't be able to tell. The mount is still good up to this day.
https://r.tapatalk.com/shareLink?url...3&share_type=t
Polyurethane Engine Mount (not 3m)
KTS is offline   Reply With Quote
Old 06-27-2017, 10:22 PM   #5
tmontague
tmontague's Avatar
Did the metal sleeve come with the poly bushing, or did you have to order that separately from red line?
This seems like the best option and something I'll likely do down the road when my poly dogbone gives out
Old 06-27-2017, 11:07 PM   #6
KTS
KTS's Avatar
Drives: Vitz RS
The prothane mount was cut to size. I don't think that they replaced the metal sleeve when they removed the old rubber. Most shops locally will burn out the old rubber with a blow torch.
Sent from my SM-G920V using Tapatalk
Old 06-27-2017, 11:25 PM   #7
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
I cut chunks of silicone couplers (for intake connections, etc) & jammed them into the voids of the torque mount & the trans mount.
for the fluid motor mount, I gutted it and filled the top and bottom with 60a urethane
idle is noticeable but otherwise its not bad at all
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 06-27-2017, 06:03 PM   #8
MatthewMenze
Awesome! I imagine the 2012 has a similar rear mount? That would work perfect for my needs.
Thank you!!
Old 06-27-2017, 10:08 PM   #9
CoryM
Drives: 2009 5-door, 5-speed
Other option is to take the stock bushing out of the dogbone and press it back in rotated 90°. Costs you nothing and you can always go back to the way it was if it shakes too much.
FYI the Yaris is a pretty rough little engine at idle. You will get a decent amount of vibration with stiffer mounts.
Old 08-14-2017, 07:55 PM   #10
Balbleague
Drives: Man
Updated:
For those who have more experience with porting, do you have any suggestions before I put this thing back together?
Balbleague is offline   Reply With Quote
Old 08-17-2017, 09:45 AM   #11
Jerkratt
Jerkratt's Avatar
I have the TRD engine and trans mount. I know Beatrush sells an upgraded dog bone mount
"It hurts more when its wet"
Japanese engine into French Yaris 1.0 2002 Jamie101 DIY / Maintenance / Service 5 02-12-2018 10:41 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
Info regarding Engine change. sheraz2000 General Yaris / Vitz Discussion 5 01-08-2009 12:51 AM
