![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
TB Spacer + TB polishing
im going to hit up shop this weekend that provides TB spacer and TB polishing on 1NZ..i will update 😎
![]() Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
seems expensive considering you can get a 1zzfe throttle body for $30
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
I don't recall the last time i saw one for less than 90?
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
2ZR swap. DO IT! Ask how!
its about $90..its not bad...😕
we have a lot of fast and furious watchers imaging things..😂😂😂😂
| Echo HatchBack 15X6.5" 42ET Nitto NeoGen 205/50R15 . Rear Spacer or not ! | mpcv2000 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 02-10-2014 10:32 PM |
| Spacer 1NZ-FE to 1ZZ-FE | EdgarTRD1.8 | Caribbean | 2 | 03-24-2012 10:37 AM |
| Best Rear Spacer | SeriousBlack | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 08-22-2011 02:44 AM |
| Wheel/hub spacer, PLS help | evo165 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 08-18-2009 02:21 AM |
| Toyota Throttle Body Spacer: the Best Fuel-Saving Device | davidmills | Performance Modifications | 1 | 07-01-2007 11:38 PM |
