![]() Drives: 2008 Yaris Join Date: Jun 2016
Yaris Horn Problem
Hello - my horn on my 2008 Yaris hasn't been working for the past month or so. At one point a few months ago, the horn would randomly go off and I'd have to hit/jolt it to make it stop. Now, the horn isn't working at all.
I checked the fuse, and it was blown, so I replaced it with the spare. The spare didn't work either - so I removed it, and saw that now the spare fuse was also blown. I replaced it again with another good fuse, tested the horn (no luck), and then noticed the third fuse had now also blown. The fuse does not blow until I hit the horn. Any ideas on what may be causing this? I've read some suggestions, and I keep seeing the horn relay mentioned, but I haven't been able to find any good information on where the horn relay would be for this. I read it's supposed to be right under the horn fuse, but there doesn't seem to be a relay there. I've attached a pic of the fuse box. The horn fuse is the slot at the top with no fuse attached. Any help is much appreciated.
| Yaris Horn Relay | mekman | DIY / Maintenance / Service | 3 | 06-29-2016 01:56 PM |
| problem with co-worker yaris, need opinion on what it could be. | Adriaan | DIY / Maintenance / Service | 5 | 10-20-2014 06:39 AM |
| Yaris TR 1.3 '08 AC problem | Eeman | DIY / Maintenance / Service | 5 | 07-03-2014 04:59 PM |
| Yaris Reverse Problem - Automatic | fowmd887 | General Yaris / Vitz Discussion | 3 | 06-28-2012 06:11 AM |
