Old 07-04-2016, 11:31 AM   #1
misterfly
uk hardcore for life
Drives: toyota yaris 2008 sedan
2008 Yaris ac system
Hey guy, last week i have made at dealership a decontamination of the ac system and refill , the ac have worked 15 minute and now it's blow again hot air , i have call the stealership but it's charge me max 2 hour to make a new diagnostic wich it's 275 $ cad , do you have any idea what the problem can be ?
Last week he have make the refill and check for leak, i got no leak.
Thanks
misterfly is offline   Reply With Quote
Old 07-05-2016, 12:40 AM   #2
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
Make them accept the cost, as the job you paid them for didn't work for long.
Sent from my LG-D801 using Tapatalk
tarkus is offline   Reply With Quote
Old 07-07-2016, 04:38 PM   #3
esse10
Drives: 2009 yaris 2 door
A/C
on a 2008 yr old model maybe the condenser is really dirty, check that. Does your engines electric fan come on when you turn the A/C on ?
You can't have cold A/C if the condenser is not getting air flow through it.
You know how to read/use manifold gauges? hook those up and see what the low and high pressures are before and after you turn on the A/C.
with A/C off both low and high pressures should be equalize and should be around 90-100 psi. when the A/c is turned on the low comes down to about 30-40 psi and the high go's to about 150-175psi. depending on ambient temperature.
esse10 is offline   Reply With Quote
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
2008 Toyota Yaris passenger side view mirror change KOOCHO DIY / Maintenance / Service 1 12-01-2012 09:52 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
