Old 08-05-2016, 01:29 PM   #1
pat005
Drives: 08 Yaris 3-Door
Push button starts, but doesn't stop engine
08 Yaris HB
So I bought an remote start kit which came with a push button start. I have everything pretty much working except the push start button. I'm suppose to leave my key in the ON position of the car, however when I push the button to stop, the engine remains on but some of the electronics are off until I move the key to off. But if I move the key to off first, some of the electric components remain on until I push the button.
Did I wire something wrong? Theoretically I should be able to leave a cut key on the ON position and just use the button. remote start also doesn't work unless there's a key in the on position as well.
Support guy says I should remove the ignition cylinder but I tried to follow an old guide but I tried to push the button for the cylinder but couldn't get it out for the life of me.
https://imgur.com/2kpbzQd for wiring diagram
pat005 is offline   Reply With Quote
Old 08-05-2016, 10:35 PM   #2
Sounds like the kit has some design issues.
Old 08-08-2016, 11:04 PM   #3
enviri
enviri's Avatar
Drives: 2010 Yaris
Dont you have to hold the button for 3 seconds or something?
Old 08-10-2016, 07:32 PM   #4
pat005
Darn, I was hoping I just missed something while wiring because I didn't want to remove the system to return it. side note, how do I go about removing the ignition cylinder?
key->acc, push the pin, pull out 1/4". I know i'm suppose to remove the "key sense" but not sure if its the top right or bottom left.
http://imgur.com/a/LJoW0
ignition cylinder, push start
DIY: Engine Grille Block BailOut DIY / Maintenance / Service 39 11-11-2017 09:33 PM
2009 Toyota Vitz/Yaris 1.3L hatchback Engine Heating Up VitzBD DIY / Maintenance / Service 8 09-22-2015 07:01 PM
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
