![]() Drives: 2007 yaris Join Date: Aug 2016
Engine misfire problem
Okay, i've had one heck of a time trying to solve this misfiring issue and i'm hoping someone can help.
2007 yaris at 195000 miles. Had the water pump and the headgasket replaced a couple months ago a week ago i got a check engine light, had the code read, it was misfire on cylinder 3 ...so i had the sparks replaced after about 40 minutes of driving again i get the same code ...so i replace the coil (probably should have just swapped them to see if the misfire moved but i was impatient) after a bit the misfire reoccurs Considering i just had the headgasket done i wanted to ensure i was getting enough compression, had 3 and 1 tested, they were fine. the guys who did my headgasket said the intake valve looks good and engine was in good condition. They suggested the next step might be to swap injectors to see if problem follows it.... which i did today and.... now i have a misfire on 1 2 and 4. So i'm worried that i did something wrong. The task itself seemed easy enough, remove the two bolts holding the injectors, move the metal pipe holding them up so that i can access them, wiggle them out and exchange? Did i potentially turn a single misfire issue into something bigger by doing something wrong or does the 1 2 4 tell us something more and i'm just not able to connect the dots. |
| Tags |
| misfire |
| Engine Power problem | johnnashfcup | DIY / Maintenance / Service | 5 | 12-16-2015 07:40 AM |
| 1ND-TV engine swap | Daox | Fuel Economy Forum | 11 | 10-01-2015 03:49 PM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 09:02 AM |
| engine swap update | Adriaan | Canada | 5 | 03-03-2009 07:21 PM |
| Yaris 06 H/B Engine Cutting out problem.. | Farenheit | General Yaris / Vitz Discussion | 3 | 09-14-2007 02:21 PM |
