Old 10-04-2016, 12:46 PM   #1
ejaf
Drives: 09 5MT
Question Bleeder valve fitting same size on brakes as clutch?
Hi all,
Prepping to bleed the clutch this weekend on a 2009 4DSD 5MT. Running to Home Depot to pick up clear tubing, and I forgot to check whether the bleeder valve fittings on the brakes are the same size as the bleeder valves on the clutch (I'm assuming they are).
Won't be able to get home prior to the trip...anyone know off the top of their heads?
TIA...Eric
ejaf is offline   Reply With Quote
Old 10-04-2016, 01:15 PM   #2
bronsin
bronsin's Avatar
HAve someone operate the clutch while you watch to see what moves. It should be pretty easy to see the clutch cylinder and attached bleeder bolt.
I do believe the tubing that fits the brake bleeders will also fit the clutch cylinder. Get two or three sizes a couple of feet long each. Its pretty cheap....
Old 10-04-2016, 01:27 PM   #3
ejaf
Drives: 09 5MT
Thanks...I knew where the clutch valve was, and measured some non-clear tubing I had in the garage which fit it. Just wanted to know if the brake bleeder valves were the same, but I guess it doesn't hurt to get a couple of different diameters.
E
Old 10-05-2016, 08:58 AM   #4
dogsridewith
Drives: 2007 2-door hatchback
Bleeding clutch
Used search function here and found some pretty complicated ways to bleed various parts of the low-pedal-shuddering-clutch.
I got a little more pedal freeplay doing this:
Drive right front wheel up a ramp to help move any air bubble in slave cylinder to location of bleeder (undoubtedly same as valves on wheel cylinders).
See uni-reservoir (brake and clutch) is quite full, and remove cap.
Suck some fluid w/ a Mityvac, and replace reservoir cap.
(Park the right way on the right hill would be even easier...noting you can't get much ramp under the front of a Yaris hatch.)
Old 10-05-2016, 11:39 AM   #5
bronsin
bronsin's Avatar
Hmm I put mine on ramps all the time to change the oil and inspect the underside.
Just shove the ramps under until the plastic moves!
Getting Rid of the infamous Clutch "Shudder" tmontague DIY / Maintenance / Service 14 07-08-2023 01:56 PM
Clutch delay valve? NJ Drive Performance Modifications 16 01-21-2013 09:36 AM
Anyone care to make a DIY on break flushing and bleeding? Hard_Yaris DIY / Maintenance / Service 19 05-04-2011 03:49 PM
Speed bleeder size/bleeder valve spec swidd DIY / Maintenance / Service 0 04-21-2011 02:31 PM
