![]() Drives: Yaris Blue HB 5 speed Join Date: Oct 2008
problem acceleration after battery jumpstart
Like the fool that I am, I left the lights on all day on my 2007 Yaris manual transmission
and came back to dead battery. I had the battery jump started and now the car has problems on acceleration. Starting on, I have to press down harder on accelerator pedal to get going and when I shift, I also have to press down a little more and shifts are not as smooth. Any idea of the problem and solution?
![]() Drives: 2012 Yaris 3d LB Join Date: Feb 2017
Maybe the computer has to relearn how you drive since yaris has an electronic throttle. As for the not so smooth shifting, I have no idea but I find it unlikely that it has to do with the electronics since you are the one doing the shifting.
I'm just spitballing. I'm interested to know what it is. |
I imagine by now the OP no longer has an issue. Whenever the battery has been drained or disconnected, the ecu goes through a learning phase. Until it figures everything out again, you experience extremely low and erratic idle.
| Toyota Recalls | auxmike | General Yaris / Vitz Discussion | 535 | 02-25-2021 06:13 PM |
| Ohm's Law and Setting Amp Gain | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 24 | 03-13-2012 09:34 PM |
| Toyota Yaris Battery Light On - Repair | gabo | General Yaris / Vitz Discussion | 1 | 08-24-2011 07:21 AM |
| Tests fail to duplicate acceleration problem in Prius | JBougie | Off-topic / Other Cars / Everything else Discussions | 36 | 03-29-2010 03:34 PM |
| I think it's a battery problem.. don't you ? | jorizk | DIY / Maintenance / Service | 10 | 08-11-2009 02:27 PM |
