Old 12-25-2016, 11:44 PM   #1
91mustang
Drives: Charcoal 2012 Yaris SE 5 Speed
Suspension questions
I have a 12 Yaris SE, rear disc brakes of course.
This is what I have,
Tanabe sustec coilovers (not installed)
White line 22mm rear sway bar ( not installed)
White line 14mm front camber bolts (not installed)
What do I need to buy to ensure a proper alignment for the front and rear together? Do I need camber shims?
Should I install the camber bolts when I put the coil overs on or let the Toyota dealer install them?
Does anyone know part number for energy suspension front sway bar bushings? My car has 53k miles so I'm sure they are okay, but like to have them on hand.
91mustang is offline   Reply With Quote
Old 12-26-2016, 05:31 PM   #2
CoryM
Drives: 2009 5-door, 5-speed
If you want more negative camber than stock, then install the camber bolts prior to sending it for alignment and tell the shop what camber you want. If you just want to reduce tire wear for normal driving, you are probably fine without the camber bolts (but bring them along for when the alignment is done just in case).
Rear camber shims are not required, and far as I have seen the only ones available are plastic (which are not safe).
Old 12-27-2016, 12:12 PM   #3
91mustang
Would you have any suggestions for what to tell them to set the front camber on with the white line bolts? I have really no idea what would be ideal. I like to take turns aggressively and wouldn't mind getting into some autocrossing with the car but that is about it for now.
Thank you!
Old 12-27-2016, 02:58 PM   #4
CoryM
You're probably going to want -2.0° to -2.5° camber up front. -2.5° is going to be around max the bolts will get you. If you drive hard and autoX, this will help reduce outside edge wear and make the car faster. If you don't drive hard, you may see some uneven tire wear.
Cheers.
Old 12-27-2016, 03:58 PM   #5
Yaris874
Yaris874's Avatar
Drives: 07 yaris hatchback
Hey u have a 4 door or hachtback
Sent from my SM-G935T using Tapatalk
Yaris874 is offline   Reply With Quote
Old 12-27-2016, 06:36 PM   #6
91mustang
It is a 4 door hatchback se.
Old 12-27-2016, 06:37 PM   #7
Yaris874
Yaris874's Avatar
Ok the u got the part# all ready
Old 12-27-2016, 06:40 PM   #8
Yaris874
Yaris874's Avatar
For the camber bolts and the shims
Old 12-27-2016, 09:12 PM   #9
91mustang
The front camber bolts are white line brand, part # KCA414.
I didn't order any shims, CoryM didn't recommend to get any.
Old 12-27-2016, 09:17 PM   #10
91mustang
Thanks for the awesome help so far, any idea about the sway bar bushings anyone?
Old 12-29-2016, 06:06 PM   #11
91mustang
I was just looking at the info on the bolts, why do they say the max they will give is 1.5 degrees camber? Anyone know?
Old 12-29-2016, 06:10 PM   #12
Yaris874
Yaris874's Avatar
The u know how much u need to fix
Old 12-29-2016, 06:12 PM   #13
Yaris874
Yaris874's Avatar
Because if u need more the 1.5 - camber u need to buy a different bolt
Old 12-29-2016, 06:15 PM   #14
Yaris874
Yaris874's Avatar
Old 12-29-2016, 07:37 PM   #15
91mustang
http://www.whiteline.com.au/product_...CA415&sq=33019
White lines site said 1.75 degrees of camber for their bolts. I'm not ordering another set at this point. So I'll just ask for the most negative camber they can set it on when I get it aligned for the front.
Old 12-29-2016, 07:48 PM   #16
Jason@SportsCar
That is typically for an installation only utilizing a single crash bolt per strut, if you want more camber you need to install two per strut. If you are daily driving the car and just looking to make it more sporty, stick with a single bolt maxed out. If you are setting up for the track get a pair at start at -3.
Old 12-29-2016, 08:46 PM   #17
91mustang
Cool, thanks Jason! I'm new to camber adjustments, does it matter if the single bolt is at the top or bottom when doing just one?
Old 12-29-2016, 09:52 PM   #18
Jason@SportsCar
For a single bolt I would put it at the top, use the OE bolt on the bottom.
Also keep in mind the advertised spec on the box is the range of adjustment, not the finished product. If your car is +0.5 camber stock, and bolt allows for +/-1.75 adjustment, best case you will have -1.25.
coilover questions why? Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 05-11-2012 01:58 PM
Finishing my suspension ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-15-2011 09:26 PM
NSW Proposed Suspension Restrictions Bella Australia 0 09-22-2010 01:51 AM
Brand New Suspension Questions... silaypalmer13 DIY / Maintenance / Service 5 03-13-2009 01:26 PM
A few questions about suspension, tires, and brakes. supmet Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-02-2009 04:55 PM
