Old 03-23-2017, 10:27 PM   #1
Pinchlite
Drives: 2007 yaris HB
Rear wiper blade freezing up...fix?
I notice anything below -10 or so the rear wiper does not work that well as the blade gets frozen up(I have new oem rubber btw)
I came across this pic and it shows arm vertical.
This would make the rubber more in contact with heated part of window.
I suppose I would have to modify the motor mounting counter clockwise?
feedback/opinions always appreciated and hope this is a worthy post?
Pic Related:https://imgur.com/17hcoUd
Old 03-23-2017, 11:42 PM   #2
SirDigby
Drives: 2007 yaris 3 door
it must have a different motor installed. our motor is at rest on the left and rotates clock-wise. in this set up it would only wipe the small corner and rub all down the side. logically it probably has some other motor mounted that rotates counter clock-wise. or maybe you can take the motor apart and switch the direction somehow. that would be interesting...
Old 03-24-2017, 05:28 AM   #3
Pinchlite
This is how Canadian model Hatchback models should have had wiper mounted.
How the resting position is know,horizontal bottom of window the blade is not resting on heated part of window.
Old 03-24-2017, 06:45 AM   #4
There are diys on here about getting wiper to vertical rest position. It does not involve replacing any parts with something different.
Old 03-24-2017, 06:49 AM   #5
Pinchlite
I will search google.
This mod would definitly keep wiper blade from freezing up which is really,really annoying.Like i mentioned anything -10 and under(Perhaps less even) and the rear wiper is useless.
Got it!
Vertical mod:http://bruneicompacttuner.blogspot.c...wiper-mod.html
This mod will be done aswell.Day one with yaris and i did not like how blade would not fold out.
https://www.youtube.com/watch?v=50btxtAuHfE
Old 03-24-2017, 10:25 AM   #6
Our own local DIY thread for the vertical wiper mod for those who don't know how to search YW.
http://www.yarisworld.com/forums/sho...vertical+wiper
Old 03-24-2017, 09:46 PM   #7
SirDigby
wow! these are awesome!
I can't believe it's that easy!
Old 03-24-2017, 09:54 PM   #8
Pinchlite
This will definitly keep the blade in the warm/er zone of the window.
Should'int have the blade freezing up...hopefully.
Some have mentioned the rear wiper as not working properly,or doing a poor job in general but for me with new rubber the wiper works superb in +0 temps.
Others have removed completly but personally I could not see myself not having a rear wiper as its an essential for me.
Old 03-26-2017, 12:35 PM   #9
SirDigby
I don't ever use it because I figure it had build-up and would make things worse, but I like the idea of it looking all broken but functions correctly. also, it looks line it's more aerodynamic in the up position...
P1 rear wiper arm on P2 Chariz Cosmetic Modifications (Exterior/Interior) 1 10-12-2014 07:08 PM
Rear wiper doesn't make full contact with window. How to fix? Silverkarn DIY / Maintenance / Service 2 06-09-2014 09:50 PM
Rear Wiper "Coverage" Problem Solved Onwrdigo Third Gen Yaris General Discussion 5 06-20-2013 07:48 PM
Removing rear wiper fred812 Cosmetic Modifications (Exterior/Interior) 34 01-27-2013 01:22 AM
