Old 03-18-2017, 11:21 AM   #1
frank2005
Drives: Toyota Echo RS 2005
Trailer with echo 2005 HB tow capacity ?
Hello,
I call Uhaul max trailer size is 5x8
little move with toyota echo hb ?
Load 800LBS MAX ?
Overweight
Risk broken the chassis?
frank2005 is offline   Reply With Quote
Old 07-09-2017, 06:47 AM   #2
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
nope, yer good
use 3rd gear, no 4th on heavier loads
Old 07-20-2017, 08:07 AM   #3
praivo
Drives: 2000 SCP10, 2001 NCP13
I've towed 1400+ lbs (and once over 1600) multiple times with no issues.
praivo is offline   Reply With Quote
Old 07-20-2017, 03:14 PM   #4
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
I have a 2012 Yaris, so these figures may be a bit different for your echo.
The Australian manual for the Yaris lists a maximum trailer weight of 900 kg (1984 lb). This is reduced to 550 kg (1216 lb) if the trailer does not have brakes.
800 lbs is well within the capability of the Echo or Yaris.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
2005 Echo RS Cluster in a 3DR 2004 Echo Liftback . mpcv2000 Canada 73 05-20-2021 07:14 AM
Hi im new here i bought Toyota echo RS 2005 frank2005 General Yaris / Vitz Discussion 21 12-12-2016 09:27 PM
Toyota Echo 2005 RS Performance Upgrade Help tattoo007 Canada 4 03-10-2016 09:30 AM
2005 Echo RS Performance Upgrade Help Required!! tattoo007 Performance Modifications 2 03-08-2016 06:24 PM
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 03:23 PM
