Old 07-20-2017, 06:44 PM   #1
Cezza07
Drives: 2014 Toyota Yaris L
Performance Mods
Okay so I have a 2014 Yaris (03/14) 4dr, and it's a nippy little thing!
I was just wondering what type of performance mods all you guys have done on this generation of Yaris?
I live in California, so I am limited as to what I can LEGALLY do on the engine and such, however I am thinking about doing the suspension, low profile tyres and nicer rims (I know those two are cosmetic rather than performance)
I'm thinking about doing a RAM intake too, but I will have to remove it and put the box back in every 2 years, so we shall see!
2014 Toyota Yaris L
Cezza07 is offline   Reply With Quote
Old 07-20-2017, 09:17 PM   #2
SirDigby
Drives: 2007 yaris 3 door
suspension and tires are the most important part of performance. do that first.
remove and install airbox=15 minutes
1zz throttle body is great. $35 at pull&save or whatever...
i have a ported manifold with spacer for sale
http://www.yarisworld.com/forums/showthread.php?t=58478
Old 07-21-2017, 11:25 PM   #3
m.flores.0928
m.flores.0928's Avatar
Drives: 2014 Yaris
Performance Mods
You can swap the 1NZ for the 2ZR from a Scion xD or Corolla. That adds 30 easy horsepower and no considerable weight gains. Transmission bolts up the same because those cars use the same (automatic) transmission, albeit with a different flex plate. It's fairly easy as far as motor swaps go but not all that cheap and it's also quite difficult to source a good engine for decent price. I was going to just get a salvage donor car from a local yard. Motor mounts up pretty easy but getting the ECU properly wired up is tricky, you would also need a custom fabricated exhaust. It's totally smog legal too as long as the motor is from a 2014 model year or newer vehicle. (I live in cali too, I've done my research, I just haven't started yet because I'm still preparing my budget.)
For cheap stuff, get good wheels and tires and a rear sway bar. That will tighten up the car really well. Perhaps even some chassis bracing. Steel brake lines would be a good addition as well.
Can't go wrong with good CAI and exhaust too, combined with a 1ZZ throttle body. I've heard of people using 1ZZ injectors too. Those would be smog legal too if you hide them well enough with a CARB legal CAI.
m.flores.0928 is offline   Reply With Quote
Old 07-23-2017, 09:38 PM   #4
Cezza07
You can do exhausts in Cali? Everywhere I have seen, it all says "not for sale/use in states: California.
It would be nice to get a better exhaust and such.
CAI is going to be the first port of call.
And I have been looking at throttle bodies, but couldn't find any. (I'd have to get one off of a corolla or something - you say?)
Tires I'm going to get some decent ones, and some nice alloy rims too, as the steels look kinda pants.
The suspension I am looking into, but I don't want it too stiff because the Cali highways SUCK.
Thank you for all replies though!
2014 Toyota Yaris L
Old 07-31-2017, 02:12 AM   #5
m.flores.0928
Drives: 2014 Yaris
You can have an exhaust in Cali as long as it still has a cat and muffler (cat for smog and muffler for noise limitations. As long as the muffler isn't STUPID loud, you'll be fine)
However, most people save their OEM parts and for smog then they run the aftermarket parts afterwards. I would recommend registering your car in a class 1 smog area (small rural towns) because you only need to smog your car when you sell it, otherwise you never have to smog it in Cali
A 1ZZ throttle body is a pretty straight forward swap, those are easy(ish) to find for cheap. You can look for them on eBay or junkyards, etc. corollas and celicas with the 1ZZ motor
And yes Cali highways are garbage. I feel you there.
Old 07-22-2017, 05:57 PM   #6
SirDigby
you would only install 1zz injectors if you are running forced induction or E85. if you install them without a need, you will run rich and do damage to catalytic converters and sensors. no gains to be had from injectors alone...
Old 07-22-2017, 06:10 PM   #7
m.flores.0928
Drives: 2014 Yaris
Gotcha. To be fair, I said I HEARD of that. I didn't do much research on injectors.
Old 07-29-2017, 03:21 PM   #8
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
In that case you can just put in an AfE drop-in air filter also removing the carbon filter from the air box. Then put in a 1ZZ (Corolla/Matrix)throttle body. That will help open up your performance in a way that won't be visually obvious.
Sent from my phone. Please excuse any typpos.
tarkus is offline   Reply With Quote
Old 07-30-2017, 01:21 PM   #9
tarkus
tarkus's Avatar
Another fairly straight forward mod is to replace the crank pulley wheel with a low-weight pulley or an underdrive pulley
Old 07-30-2017, 01:46 PM   #10
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
If doing that, try to get a pulley in either a black or grey colour, so if doesn't stand out...
What are the best performance mods? Focus_Sh1ft Performance Modifications 8 04-07-2010 12:06 PM
Fuel Economy W/ Performance Mods AutoXBot Fuel Economy Forum 21 08-07-2009 07:41 AM
Performance mods that won't affect/will hardly affect gas mileage?? Mr.Yaris Performance Modifications 15 07-30-2007 12:32 AM
