Old 05-23-2020, 03:28 AM   #1
Branderrp
Drives: Yaris 2006 NCP91R
Front suspension boot cover broken
Hey all, was wondering if a loose boot cover on the front suspension will cause any trouble? I see a bit of rust on where the the cover was on normally.
Also, there's a bit of clunking noise when braking with moderate pressure when in drive (light braking is fine)
Notes:
- car is jacked up
- no play in the suspension (3-9 6-12 o clock hand shake test)
- no wobbles or clunks when driving normally (only when braking)
Edit: brake clunking disappeared when removing the swelled rubber in each lower guide pin caliper
Branderrp is offline   Reply With Quote
Would these front suspension parts be any good? Pinchlite Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 02-09-2017 10:07 PM
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 03:30 PM
Torque Settings, front suspension Nimble Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 02-21-2007 01:00 PM
How can I cover front license plate hole hans_fh General Yaris / Vitz Discussion 13 01-03-2007 12:58 PM
